Someone on Facebook commented yes. I can’t see why not. The engines are most likely built at the same place.Thanks. So, then another possible angle to explore is does a Tahara plant produced LC make the same sound as the Hino / Hamura ones.
I know their are some engines built at Hino due to the issue of previous model engine issues coming out of that plant. I don't know if Tahara makes engines.Someone on Facebook commented yes. I can’t see why not. The engines are most likely built at the same place.
Piston is aluminum. Cyinder wall is a steel insert cast into the aluminum block. Piston rings are also steel.Should everything expand proportionally though? I know metal expansions can cover up manifold leaks, but that is because manifold and the engine block are at different temperatures. Cylinder wall and piston should be at the same temperature.
Plenty of warranty left and time in the year since purchase. If there is a problem it will result in performance problems or engine failure. I’d prefer no one touch mine at a dealership unless I’m experiencing mechanical performance problems. So I’m going to drive on and enjoy it, if there’s a recall or I experience any issues I’ll take care of it then. I’m still under 1,000 miles, looking forward to seeing what the break in oil looks like, about 300 miles to go.are you? Because that same sound was tracked down to my engine cylinder 1 issue. engine torn down in pics on post 1. I'd say taking it to your dealer to have them diagnose it would be a better option.
That's about where I'm at with this whole thing as well. If it rises as a problem I'll deal with it then. I don't trust the dealer techs to diagnose it on a brand new platform.Plenty of warranty left and time in the year since purchase. If there is a problem it will result in performance problems or engine failure. I’d prefer no one touch mine at a dealership unless I’m experiencing mechanical performance problems. So I’m going to drive on and enjoy it, if there’s a recall or I experience any issues I’ll take care of it then. I’m still under 1,000 miles, looking forward to seeing what the break in oil looks like, about 300 miles to go.
It’s probably the opposite, disengaging of the ICE from the transmission.The only noise that I've noticed that was new to me was the sound that it makes when deaccelerating to a dead stop. It sounds like a muffled clunking noise, which I think is the electric motor disengaging. Not enough that I'm worried about it at all but I will keep an eye on it.
This and it is also downshifting when stopping - it is engine breaking into the electric motor: regeneration. The LC has regeneration built into the transmission and electric motor where it turns the motor backwards through the transmission.It’s probably the opposite, disengaging of the ICE from the transmission.
The occasional stutter when coming to a stop is a little jarring. Certainly far less smooth than every other hybrid I've owned (priuses & rav4). Obviously a completely different hybrid system, but it stands out as one of those "huh, that's a little rough" kind of things. My wife noticed it too and asked "uhhh, is it supposed to do that?".It’s probably the opposite, disengaging of the ICE from the transmission.
Seriously...... What difference is there if the electric motor disconnects from the engine or the engine disconnects from the electric motor!It’s probably the opposite, disengaging of the ICE from the transmission.
I found that smoothed out. It’s the switch from the charging the battery break to the hydraulic break.The occasional stutter when coming to a stop is a little jarring. Certainly far less smooth than every other hybrid I've owned (priuses & rav4). Obviously a completely different hybrid system, but it stands out as one of those "huh, that's a little rough" kind of things. My wife noticed it too and asked "uhhh, is it supposed to do that?".
Yeah quite different compared to regular Toyota hybrids. Regular Toyota hybrids like prius and rav4 have an advance planetary gear transmission that couples electric motors and ICE. So there is no need to decouple things from each other with a clutch. Transmission can simply cut to the power going to/from the engine or the electric motor, or combine or split power going to/from each. This is how they achieve really good MPG numbers. ECU keeps the engine at its peak efficacy (around 2500 to 3000 RPM, depending on engine) and the transmission sends the needed power to keep the car moving while the rest is slit to spin the electric motor to charge the battery.The occasional stutter when coming to a stop is a little jarring. Certainly far less smooth than every other hybrid I've owned (priuses & rav4). Obviously a completely different hybrid system, but it stands out as one of those "huh, that's a little rough" kind of things. My wife noticed it too and asked "uhhh, is it supposed to do that?".
LC does not have regen front brakes.This and it is also downshifting when stopping - it is engine breaking into the electric motor: regeneration. The LC has regeneration built into the transmission and electric motor where it turns the motor backwards through the transmission, in addition to the regenerating front brakes.
Does it even have regen breaks at the wheel at all?LC does not have regen front brakes.
no vehicle(unless it has a motor at the wheel) has regen braking located at the wheel. Regen braking is, as you described, accomplished by the electric motor.Does it even have regen breaks at the wheel at all?
As far as I understand, regen breaking is achieved through the electric motor as the momentum of the car spins the electric motor, which generates current and charges the battery. Electromagnetic field created at the motor during this process generates the resistance that slows the car down.
When you press the brake, hybrid controller increase the current that is being pulled by the battery, this increases the electrical resistance at the motor, slowing the car faster, but also generating more current to charge the battery at a higher rate. Increasing the resistance to increase current (and therefore slowing the car down faster) is less efficient, as it generates heat both at the motor and the battery, so letting the motor slow the car down by simple coasting is more efficient. Heat generated is also the reason why you should make sure hybrid battery vents are not blocked.
You forget that camshafts were snapping in the early 5.7L V8s.Good thing that Toyota moth-balled that V8. Man did that thing have issues.![]()
