Where are the ones that we buy from the dealership made?Ordered OEM Toyota filters (90915-10009) that are Made in Japan, not Thailand or China for my upcoming oil change...
Under both front wheels? Or both on one side?I use two ramps. They sure make it easier for my old body to get under there, which also makes it easier to look around at the undercarriage.
I think Toyota has a couple of countries that make their filters, the country of manufacture is always printed on the box, if I remember correctly the case I purchased from the parts counter state "Thailand". The carCareNut guy did a video on knock off filters. He said many knock offs state the were made in "Japan", the color on the box was slightly off and the print was slightly off.Where are the ones that we buy from the dealership made?
Where?
I would use one ramp under each wheel the first time you do it, so it will be easier maneuvering for you. Horrible Freight has steel ones. I have those in Florida. I bought some plastic ones in NC at AutoZone. Both work very well. The steel ones might be a skosh taller. Either will do.Under both front wheels? Or both on one side?
I see ramps available with about a 2.5โ rise, and others with about 6โ rise. Not sure the 2.5โ would do much, but I guess they would minimize retained oil caused by the tilt.
I like these too. I have run the gold plug and dimple plugs in all my cars without any issues. In the oil pan, transmission case etc.If anyone is interested in a magnetic drain plug that is good quality and a direct replacement. It uses the stock crush washer. Also filter mag makes a oil filter magnet that fits the small oil filter. Many of the Amazon or online drain plugs are aluminum and not very durable.
This is information only, not intended to start a debate on magnetic drain plugs and filter magnets. Some people use the oil drain valve, some people use the stock drain plug, some people use a magnetic drain plug. This is personal preference. There is a lot of cheap China replicas out there and makes it difficult to find quality aftermarket parts.
AP03 M12x1.25 GoldPlug Magnetic Drain Plug
Uses Extra Washer โ SW-03 Commonly used in Toyota vehicles post 1985 15mm Hex Head M12 x 1.25 Threads, 11.5mm Thread Length, 15mm External Hex, 22mm dia. flange, 24mm OALgoldplug.com
Choose Your FilterMag
www.shopfiltermag.com
Iโm sorry. BOTH front wheels. At least for the first time you do it, as you will have more room to work. Once you see the oil pan drain plug, you can decide if you are going to get OCD about an extra ounce of oil in the pan, that might come out if you are only up on one ramp under your front drivers side wheel.Thanks, @ultane for that info. But from what you said, I can't tell if you're suggesting to use ramps for both front wheels, or both left wheels.
