JBL Stereo
In the Tacoma, it's under that hump in the carpet. Below is a screenshot of the TacoTunes YouTube video where they were working on a 2024 Tacoma with the JBL amp and the front seat has been removed so they could pull the carpet up and get to the amp.
Try not to get distracted by the gratuitous eye candy at the beginning of the video and skip to 00:45 to see her pulling the amp out.
Yup it’s under the carpet under the driver seat. Thanks for that
Has anyone figured out how to add an eight track tape player in these things yet?
Back when I was a kid in the late 70's, my parent bought a pimped out Winnebago. It came complete with an 8 track player in the dash PLUS one in a built-in stereo in the "living" area of the RV Even more exciting was the record player that it had! Trust me, it didn't work well on the road. :p
Full Disclosure: The team at Beat Sonic installed my amplifier for free in return for letting them film the installation for their YouTube Channel.
I went over to Beat Sonic today to have the amplifier installed in my vehicle, and I'm happy to report it was absolutely worth the time and effort.
The amplifier cleared up some of the muddle I was hearing even when reset to the factory settings after installation. On the way home I listened to Amazon Music, Apple Music and music from iPhone, and all sources were cleaner sounding to my ears... even Sirius XM which usually sounds awful was markedly better.
It's hard to describe something as subjective as sound, but my thoughts were immediately endorsed by my opinionated teenage daughter and my tween boys who noticed the difference without my soliciting their opinions.
Eric and his team in La Mirada are good people, so if you get a chance, or if you're looking for an easy upgrade to the your stereo you should give them a shout.
Before I go into my essay below, let me say that I was communicating via email with the guys at Beat Sonic. They were very responsive and had many ideas and tips to try and resolve my issue.
The whole Beat Sonic amp and the JBL setup is confusing me. I installed it as well and I do think it sounds better but I'm not sure if that isn't just the placebo effect...."I installed an amp and now it's louder and sounds better!". The reason for this confusion is that I was attempting to set up a powered subwoofer (PS) and having issues.
I'd used the Beat Sonic BH10 speaker harness that (according to their site) plugs in between the Amp output and the factory speaker harness. It has 4 pairs of aux outputs, 2 of which you are supposed to run to your PS. Now, since they are after the amplifier, I would have assumed that the signal coming out of the amp would be "speaker" level output. However, when I plugged it into my PS, even though I could get a signal, the volume would NOT change, regardless of the volume of the rest of the system. In other words, I was getting bass thumps even when the volume was turned to 0.
I tried changing the input on the PS to be "line" level and there was no change in outcome. I moved the BH10 to be between the head unit and the amp with no change in outcome. It wasn't until I took the BH10 completely out of the picture and connected to the wires running to the OEM sub in the rear hatch that I was able to control the volume of the sub along with the rest of the system.
So, a big question for me is why is the gauge of the wires connecting the speakers larger than the wires in the harness coming out of the head unit as well as the Beat Sonic amp? Is it because the wires coming out of the head unit are really only "signal" wires going to the JBL amp which them pumps up the signal to "speaker" level and therefore needs a larger gauge? If so, how then, is the Beat Sonic bumping the volume up if it's just sending the signal downstream to another amplifier? This is why I'm conflicted about the Beat Sonic amp and whether I'm just thinking I'm hearing better. I'm not an electrical engineer and sure there is a simple explanation but I'm confused and therefore doubt has set in.
If you're adding an amp or new speakers, it might be best to remove the Beat-Sonic, which is what I’m planning to do. The Beat-Sonic improves the stock system by cleaning up the sound before sending it to the amp, but it’s not really an amp itself even though it say it is. Instead, it just filters the audio signals and sends them to the OEM JBL amp. The smaller wires are used because the signal going to the amp is unamplified, while the signal coming out of the amp is amplified.
(I see from the picture you opened up the back part where the sub is. If you have the premium JBL system how many wires were connected to the woofer?)
That's exactly what I think might be happening but wasn't sure. In that case, would it be more accurate to call it a Digital Sound Processor (DSP)?
BTW, there is another post with some similar conversation that. Here's my post there with pictures of the wiring on the OEM sub.
I was just hoping to add a powered sub since I'm pretty happy with the rest of the sound, just need a little oomph to "feel" it when I'm playing some 90's hip-hop. :)
So there are 4. Did you figure out If the two goes into the sub are full range and the the other two come out are crossed over to the other speakers. When replacing the sub for me I am planning on ignoring those extra hatch speakers since I don't really think they are needed.
So, my powered sub (PS) takes 2 pairs as input. Not sure if you need both pairs or one would suffice but since it had 2 pairs, I ran 4 wires from the connector to the 4 wires on the input of the PS. I can't remember for sure but it would not work with just 1 pair connected. That being said, I did NOT do a scientific test and test all possible pairs on the connector and just stopped when it started "working". However, once I had more than 2 wires connected, the sub started working. I'm sorry but I can't remember for sure if it had to be all 4 or if 3 would suffice indicating that perhaps I was unlucky with the first pair and got lucky when the 3rd wire was connected and got the proper pos/neg signal. If I get a chance this coming weekend, I can try to do more thorough test but I can't promise it since it requires taking the trim off the rear hatch and I've got other projects that are a higher priority right now.
I'm betting that only two wires go to the subwoofer, and the other two connect to the hatch speakers. I’m not sure which two yet—I’ll need to take apart the hatch to confirm when I install the aftermarket amp. Right now, I've swapped out the dash and door speakers and plan to add the DSR1 DSP where the Beat Sonic is currently located in the glove compartment. The Beat Sonic installation in the glove compartment makes wiring much easier since the wiring harness adapter for it taps into the high-level signals and sends them to the amp. I’m planning to cut into those wires for the new setup.
I learned something disappointing while wiring the DSP to the head unit (HU). It turns out the HU only provides one front channel output, and the rear channel wires give no output at all. I’m not sure how the faders work if it’s only one front channel. My guess is that the amp somehow manages it. I wonder if it’s the same setup for the non-JBL system.
If anyone knows work around for this let me know.
This post I found pretty much says I would have to retain the factory JBL amp and tap into the amp for the signals. I really don't want to keep that amp lol
Yeah, I'm thinking these newer stereos are much more computer than old school stereo that we are used to. I'm going to totally oversimplify here but my guess is that the head unit sends an audio signal to the amp via one set of wires and a "controller" signal via another set of wires that lets the amp know which speakers get which amount of volume or something like that. Also, the fact that there is a noticeable delay when pushing the power/volume knob in turning the unit on or off tells me that the audio system in general is more of an "app" that runs on the computer in the dash along with the climate settings "app" and the general settings "app". I'm further convinced that everything is essentially an app by the fact that I can change the temperature settings and heated/cooled seats from my phone.
Yea just complicates things. Looks like I have to keep the JBL amp and get the audio from there and use a Fix 86 $499 to clear up the audio signals from the lacking jbl amp so I can basically keep the faders operational on the Head Unit. Then from the Fix 86 I send the signals to the aftermarket amps $650 and then from the aftermarket amp send signals to the individual speakers and subwoofer.
If any one is interested the
PRX800.5V2 5 Channel 800 Watt Amplifier​
Fits perfectly in the rear storage cabinet of the Land Cruiser. It’s does stay floating since the cubby gets narrower as you go lower but sits snuggly flush so that the lid closes.
Has anyone managed to get clean sound from their Land Cruiser with the JBL Premium audio system using the OEM amp? I’ve tried speaker-level inputs with the FIX 86, but it didn’t work. I also tried leveling the audio using the AUDIOCONTROL DSP D-6.1200 amp, but that didn’t work either.
The system seems to send uneven audio that’s really hard to flatten, and on top of that, it keeps changing the frequency curve at every volume level. At this point, I’m thinking about going straight to the head unit to get a clean signal, but I haven’t figured out how to do that yet.
I got the base 1958 with the base stereo. Previous car was a 2015 BMW 335i with the premium Harmon Kardon system (8/10, for me). It was pretty great. We also have an 04 Odyssey (2/10), and an 18 Crosstrek Premium (4.5/10). I also have about 15k in a 2.1 system in the living room (9.5/10).
I really didn't want to shell out the extra cash for the LC because the 58 has plenty of features for me, I #love those headlights, and etc... My only real worry about the choice between the 58 and LC was the stereo. I like my music, and sound quality is a big deal to me. Then, about a month before purchasing the 58, we rented a Sienna in Vegas and drove it to the Grand Canyon. It had the base stereo, and I was pretty impressed. Clean, no distortion at very healthy volumes, etc. We jammed out in that thing. I find the stereo in our 58 equally impressive. The only experience I have with the JBL was during a quick Tacoma test drive. It was good, for sure. I can't really elaborate much more, since it was just a quicky, in a truck. But I'm going to go ahead and give the base stereo a 7.4/10. I mean, it's fine for me. Maybe stereo components have just come that far. Honestly, that little dashboard pop out speaker in the Tacoma would probably blow away the 6 speaker system in my Odyssey. And that's after refreshing the van speakers and head unit about 4 years ago. It still blows. Anyway, that's my experience. Loving that 58!
So what exactly does this do?
Let's you add ANOTHER amp to the vehicle with JBL system, without changing speakers or touching the original amp?
It provides clean, unaltered audio from the head unit and retains all the factory tone controls. Personally, I like that it offers a single optical output, allowing me to bypass the factory amp and connect my own amplifier. Without this, you’d need to tap into the speaker wires before they reach the speakers. The problem with that approach is that the audio from the speaker wires isn’t clean—it’s affected by the factory EQ and has missing frequencies. To recover those frequencies, you’d need to tap into other speakers, but even then, the audio quality won’t match what this solution provides.
I was playing around with my JBL system today. The sub in the rear hatch doesn’t seem to be doing much, if anything, even with the equalizer low frequency slider at max. The front door speakers seem to be producing the majority of the low frequencies for the system. I’m considering replacing the dash and front door speakers with JL Audio C2 series units. I was going to replace the subwoofer in the hatch, but probably won’t bother.
One thing I absolutely have to do is install sound deadening in the front doors. They rattle even with the low frequencies set at the middle in the equalizer.
