JBL Stereo
I have a 1958 Edition, so my stereo isn't much. Planning on throwing a bunch of money at the stereo in the Spring, though. Every professional stereo shop I've talked to has advised against putting a subwoofer in the hatch. They've more or less explained it as a subwoofer in name alone, so that Toyota can tell people the car comes with a subwoofer. Even for an aftermarket setup, the rear hatch has too many compromises to make it worth it.
The 14-speaker JBL system just wasn’t cutting it for me—it lacked fullness, and the frequencies felt off, muddy, and not harmonious. I’m not a fan of bass that’s all about the unnecessary “boom boom boom.” I prefer bass that complements the music and stays in sync with it. Thankfully, the Beat Sonic amp solved that issue for me, bringing the sound to life in a much more balanced way. Having it in the glove compartment for quick adjustments is a bonus—I can easily tweak the gains whenever I need to, and I’m really happy with the result.
That’s just my take, though, after hearing some solid sound systems. If you’re happy with the OEM sound, then stick with it! But if you’ve ever listened to a truly refined audio system (and I’m not talking about the ones blasting crazy bass down the street), you might find the stock system underwhelming, just like I did.
How did you access the wiring from the glove box? Did you still have to open up the dash one time?
I didn't open it up I just used a fishing wire and pulled it though. Was easy for me. But then again I might have been lucky. If you're talking about accessing wires behind dot Head unit then you do have to take that apart. Just be patient.
Can you update us on what you ended up upgrading on the 14 speaker JBL? Thanks!
I’ll do a full write-up when I have the time.
  • Deadened all doors
  • PAC Ampro with SPDIF adapter for clean audio
  • HELIX DSP SIX/Amp
  • Infinity Kappa 693C 6"x9" Components in the front with Infinity Kappa 303S mids in the dash
  • Infinity Kappa 603CF in the rear
  • Replaced the sub with a JL Audio 8W1v3-4
Finding a spot for the amp was challenging. I ended up cutting into the storage compartment behind the rear seat. It costs about $300 to replace the part, so I took the risk, and it worked out.
  • HELIX DSP SIX/Amp
View attachment 25002View attachment 25003View attachment 25001
Thank you for posting this. I'd bet there are quite a few of us out here eagerly awaiting your write up.
  • HELIX DSP SIX/Amp
Thank you for following up! This will help me greatly going forward.
  • HELIX DSP SIX/Amp
Hate threads like this. I've been pretty OK with the JBL 14 speaker set up. Blows away the Harmon Kardon in the BMW X5 that I had. And then I see this setup..................................
@SOCAL250 how much additional amps are you adding with that setup? I had heard you can only draw 30 amps from the battery, any issues with heat or things shutting down?
I have had worse than the JBL system, but it definitely was lacking compared to the Fender system in my 2017 Golf R that this LC replaced. It really bothered me that the doors rattled even with the low frequencies in the equalizer at the neutral/flat level. Plus the sound wasn't very clear to me. I have a Jeep where I replaced just the 3.5" speakers in the system and it sounded better than the JBL one. I ended upgrading all the speakers only in the LC and found it to be a much more enjoyable experience with improved sound quality.
So to confirm I was able to install 4" Ref 4032cfx int the front L/R Dash and 3.5 inch in the center because the 4" didn't fit there. I heard some people were not able to fit it in the L/R with 4 inch. It actually fits flush for me.
Yeah, break off two of the bracket tabs and they fit perfectly.
Edit: I just installed the 4" coaxials in the dash corners and it's a very noticeable difference over the OEM JBL speakers.
