Oil change complete at 975 miles.. No charge at dealership and he said it would not be problem for me to come back at 5k and then every 5k for complimentary service. Have to see in time if this holds true.
I hate it when that happens.I did mine today at 1,200 miles. I had plenty of room once I got the skid plates off. This was the messiest oil change I’ve done. The drain plug at an angle made it a challenge. The oil came out hit the drain pan then shot out of pan onto garage floor. I had to position the pan just right so oil wouldn’t shoot out.
I used a 5 gallon plastic bucket the second time to avoid this. Then just poured into the catch pan from the bucket. The 0-20w is like water and flows much quicker than traditional 10-30w. You can use cat litter and crush it into the concrete/garage floor standing on it twisting your feet, let it sit for a while and sweep up to get most of the oil out.I did mine today at 1,200 miles. I had plenty of room once I got the skid plates off. This was the messiest oil change I’ve done. The drain plug at an angle made it a challenge. The oil came out hit the drain pan then shot out of pan onto garage floor. I had to position the pan just right so oil wouldn’t shoot out.
I drained with just the drivers side on the ramp. Used a little smaller bucket than 5 gallon. Need something with a little taller sides because of the oil drain speed and how thin it is.I didn’t put mine on ramps so I don’t think a 5 gallon bucket will fit. I’ve had a few vehicles with the 0W-20 and never made a mess like this one did. I just wiped it up and used brake cleaner on the garage floor. I am glad Toyota went back to a canister style oil filter.
This my my Blackstone report after 200 miles and just prior to my first oil change.I just made it to a 1,010 miles. Barely 19 MPG in the city. I'm concerned about waiting for 10,000 MI to change the oil. I'm thinking about doing a quick change and sending it off for testing. I use Blackstone labs.
I took it in a 950, I’m averaging 23.I just made it to a 1,010 miles. Barely 19 MPG in the city. I'm concerned about waiting for 10,000 MI to change the oil. I'm thinking about doing a quick change and sending it off for testing. I use Blackstone labs.
Is this a good report?This my my Blackstone report after 200 miles and just prior to my first oil change.
You can read the oil analysis report at the top of the sample analysis for an explanation of the report.Is this a good report?
It is completely what you'd expect to find when the engine is first run in. IMO, a blackstone analysis that early doesn't tell us anything because the oil is literally brand new. It hasn't even had a chance to really become contaminated with anything but some metal debris. It is like asking someone to run a 5K to judge if they are prepared to run a marathon.Is this a good report?
