Hearing a rattle noise at low gear acceleration.
Hello everyone, here is the answer to my complaint about the sound of the truck, here in Peru the dealership is called Grupo Pana.
When they send me the report I will let you know.
Receive a cordial and respectful greeting.
Inform you by this means that our Grupo Pana dealership will shortly proceed to provide a response with technical support, for this purpose a technical report has been prepared that will be sent to you.
Without further ado, we bid farewell cordially.
Update. Took the dealer this morning. Was able to reproduce the sound with the Tech in the car. We could not reproduce while in park or neutral only under load while driving. The best way to reproduce the sound without going up a hill, is to hold the break @1500 rpm while driving 10-15mph. This will keep the load constant and rattle is very noticeable. This is the exact sound. You can keep this sound constant by holding the break.
The tech is going file a report directly back to Toyota. He said they had a similar issue with the new Sequoia and it was fixed with a software update.
I also open a case with Toyota.
They said it’s not a big issue and to keep driving and wait to see what Toyota says.
I am hopeful for a fix from Toyota and not having the local dealer tear apart things until they find the issue.
I think we all know first year cars sometimes have issues. Let’s hope this addressed by Toyota and fixed.
I would encourage everyone to report this at their 5k service appointment or when they go to the dealer/shop. Unfortunately, large companies like Toyota don’t really take things seriously until enough people complain.
If this is the only major issue I encounter, I will be still happy with the LC. Everything else besides some really minor items is good IMO for a first year car.
My '24 LC first edition makes this exact noise in same conditions (1500-2500 rpm, when starting from cold for first 10-15 mins of driving). I took it into the dealership and they verified the noise on my car and another they had sitting around. They deemed it 'normal' as a result, lol. I suspect that this will eventually be a recall. I pushed as hard as possible to get the service dept to push the report up to Toyota. Hopefully as mentioned, with enough pushes like this they will release a fix.
Wow, I just heard this same noise today with my FE (1100miles) while I was on a slightly inclined road and the windows down. Parked the car for an hour and then drove home without hearing it again.
I heard this a bit climbing a steep hill at low speeds with the windows down. Sounded like wastegate noises, engine wasn’t making any boost so it was bypassing.
I could frankly care less about the sound at this point.
Update -
The issue was escalated to a field engineer and Toyota corporate is aware of the issue and has confirmed multiple reports. They are researching a solution. The sound is not normal, and should be fixed. I would encourage everyone that is experiencing this problem to open a case with Toyota directly 800-331-4331.
Also have your dealer open a TAS case and have a FTS rep inspected the vehicle. Toyota is very slow to react, so the more reports may help our case.
Hopefully, they find the issue and can resolve it with the least impact to the owners. Remember Toyota released these with the issue and IMO should have discovered this in QC before they left the factory.
Also, I do not want the dealer tearing apart a brand new car to find the issue, they never go back together the same. I would like the issue isolated and that direct part fixed.
I sometimes hear a faint rattling/gurgling noise when letting off accelerator. Not sure if it’s related. Only have 1k miles on the vehicle. Anyone else heard this?
I have been hearing a rattling noise since I purchased and has been driving me crazy. I finally climbed under the vehicle with someone revving the engine and to my surprise the noise is coming from the weep hole on the back of the muffler. Covered it up and it goes away. Sounds just like something vibrating. The motor also sounds like it has marbles in it...
I’m starting to realize the motor in this vehicle is a noisy one. The transmission seems to be a bit clunky at times too
Update:
Someone on here suggest to use shell 93 fuel and it helped with the rattle when the engine is cold. I don’t think that did the trick for me. But I believe did the trick and the rattle is absolutely gone now is the old fashioned Italian tune up on the highway. I drive my vehicle got it to optimal temperature and then I just let it rip.
Can you please take a pic of the hole you covered. Also, what did you cover it with? Thx in advance
just picked up my Lc250 from service, techs were unable to replicate the issue, but reassured me if there is an issue I have plenty of warranty left, and to just drive it.
I wonder if Toyota did some type of update. I’m not noticing the noise anymore.
Update. Not sure what happened but I do not hear those rattle noise anymore. Two things I did. Warmed the engine up really good and gave it an old fashioned Italian tuneup on the highway and second was 2 oil changes at the dealership. May be there was sort of a software update that they did and never told me. But I can confirm the sound is gone.
Let’s see if others agree. I’ve rolled my window down and can’t hear the noise anymore. I’m wondering if some type of update was done.
Mine sounds like a sewing machine (loud clattering noise) when I accelerate from stop sometimes. Annoys the crap out of me. I does not do it all the time. It has just over 1000 miles on it. I hope it stops when it gets broken in. Maybe its a hybrid thing.
I've had the same "rattle" sound since i purchased my 250 in September '24, the noise is present when the vehicle is cold and under load only at low rpm. I've recently replaced the factory "skid plate" with an actual skid plate for protection right up until the crossmember behind the transmission, and the first thing i noticed was that rattle sound is gone!
^^^^^This. Is. Amazing. ^^^^^
Which skid plate did you use to replace the OEM skid plate?
A custom plate designed by one of the shops here in Dubai. its 8mm hardened aluminum with steel reinforcement bracket.
I was picking someone up at LAX and had to sit through a half mile of bumper to bumper traffic for 30 minutes. Holding the brake, not moving - I heard a consistent rattling, it was very loud and annoying from the cabin. Sounds like its on the passenger side, in front of the glovebox.
Everytime I lifted my foot off of the brake and started rolling, it stopped. I shifted to neutral/park - it stopped.
It comes back every once in a while, but seems to be a bit softened?
I just had this exact same rattle. It was stop and go and only happened when holding the brake and not moving. It went away as soon as I started rolling again. The rattle was very loud. Sounded like the passenger dash was going to rattle off, but clearly coming from the engine somewhere. It happened several times in a row before I hit the freeway.
Did you ever find out what was causing it? I only have 250 miles.
