Yes, but the 1958 doesn't have an automatic hatch so i can't use a key fob for thatI'm sure it could be done fairly easily........... but using the key fob requires no modifications......
Yes, that's what I was thinking as well for your latter suggestion.My apologies, I don't know all the differences between trim levels. With the opener switch being right there, it shouldn't be too hard to install an additional switch. The important question would be where to mount it and how to protect it from accidental activation.
Just thinking out loud, if I were to do this, I think I'd mount a momentary switch in the cubby where the jack is located (easily accessed and protected from accidental activation). Another location might be in the area where the manual unlock panel is, remove the trim panel, hard mount a momentary switch that could be reached through the open access panel and with panel cover in place, it would be protected from accidental activation.
I got curious as I didn't know exactly how the manual unlock worked.......... took off the access panel, turned the screw and the little white arm dropped down.......... then what? The owner's manual wasn't clear (to me anyways). I took off the entire trim panel to figure it out.Yes, but the 1958 doesn't have an automatic hatch so i can't use a key fob for that
Question, as I do not know........ Does the 1958 fob unlock the rear hatch? Or how do you unlock the rear hatch?Yes, but the 1958 doesn't have an automatic hatch so i can't use a key fob for that
When I unlock the vehicle by fob or door handle touch, the hatch is also unlocked. Also if I have the fob on me, the hatch unlocks when attempting to lift manually.Question, as I do not know........ Does the 1958 fob unlock the rear hatch? Or how do you unlock the rear hatch?
Thanks for helping me understand...... so if you unlock the doors with the fob, the rear hatch is unlocked but still physically latched and you have to press a button on the hatch to unlatch and manually raise the hatch. Do I have that correct? or is it a manual release?When I unlock the vehicle by fob or door handle touch, the hatch is also unlocked. Also if I have the fob on me, the hatch unlocks when attempting to lift manually.
I guess what i'm not understanding is ..... if you push the unlock on the fob and don't open the rear hatch, there is a mechanical latch that must be operated in order to open the hatch.
Great! Now I need to be sure to have a Phillips head screwdriver with me at all times in case I get kidnapped and thrown into my own "trunk" and need to break out! Probably need a trim removal tool as well as I wouldn't want to scratch the trim during a kidnapping.I got curious as I didn't know exactly how the manual unlock worked.......... took off the access panel, turned the screw and the little white arm dropped down.......... then what? The owner's manual wasn't clear (to me anyways). I took off the entire trim panel to figure it out.
Once the white arm drops, you will see a silver tab/arm, push the tab to the right. It would be fairly easy to make a tab extension with a piece tubing squished flat on one end (not completely closed, but just enough for a tight slip over the tab) When camping, you could install the extension and when not needed easily removable.
Wow! You are incredibly helpful. Thank you!!I got curious as I didn't know exactly how the manual unlock worked.......... took off the access panel, turned the screw and the little white arm dropped down.......... then what? The owner's manual wasn't clear (to me anyways). I took off the entire trim panel to figure it out.
Lmao follow EOD's instruction above. I'm going to try to figure out a way to make a mechanical solution so I don't need a screwdriver on me at all times and I can simply turn something with my hand to make it work.Great! Now I need to be sure to have a Phillips head screwdriver with me at all times in case I get kidnapped and thrown into my own "trunk" and need to break out! Probably need a trim removal tool as well as I wouldn't want to scratch the trim during a kidnapping.
Silly question but I think asking you would be quicker than searching for it in the manual.Thatโs right, unlocking with the fob unlocks all doors (I have mine set to one press unlocks all instead of requiring a second press) including the hatch. Then Iโd have to manually press the button under the hatch handle and lift to open. Alternatively, if the fob is in my pocket, pressing the hatch button will unlock.
Ha! Toyota was thinking of you...... they included one in the lug wrench kit.......LOLGreat! Now I need to be sure to have a Phillips head screwdriver with me at all times in case I get kidnapped and thrown into my own "trunk" and need to break out! Probably need a trim removal tool as well as I wouldn't want to scratch the trim during a kidnapping.
So the doors are unlocked and you press the open button on the rear hatch...... that button is an electrical switch?Silly question but I think asking you would be quicker than searching for it in the manual.
How do you program your key fob to unlock all doors and the tailgate with one press?
"So the doors are unlocked and you press the open button on the rear hatch...... that button is an electrical switch?"So the doors are unlocked and you press the open button on the rear hatch...... that button is an electrical switch?
If it is an electrical switch, adding a sister switch would be very easy.
If not, you could probably just leave the white cover thing or remove the white cover thing. I'm thinking a piece of 3/8 dia of brake tubing (flattened on one end and cut to a 2"-3" length would work. You can buy brake tubing at any parts store.
I wish that I could do that kind of sh*t!!!Looks like it would be a simple fab to sister a second switch
I think I have a different definition of "simple"Looks like it would be a simple fab to sister a second switch
