Almost 4000 miles on a FE LC. Just experienced brake squeal in reverse while backing out of my garage. Drove in rain for about 50 miles the night before. No squeal the rest of the drive today. Thought I had dodged the squeal bullet. Nope.
Would going in reverse help?So wet pads, sensors, first thing morning squeal, change in friction film. Utterly normal. Firm braking half a dozen times at the first opportunity. On most cars, the sensors, if still feeling moisture, close the pads to the rotors to dry and improve safety. Either or, visually you can tell if your rears need more bedding, keeping in mind that a front heavy bias makes it more difficult to bed rears on 98% of cars out there.
Thank you for all your insights. I’ve learned so much from reading your posts.May seem intuitively so, but perhaps not enough speed nor deceleration. But adding a load at the back and braking, the sensor will detect the higher load on the rear axle so more brake pressure would occur at the rear. Because, let’s not forget, the LC designers spec the car for heavy use. So a light LC in an urban setting will have the lowest rear brake engagement force. One two passengers, sandbags etc would tell the load sensor to use more the rear brakes. Alternatively if bedding, as the fronts fade the rears will bite more. but adding a load would be my choice- some weights. Sandbags etc then do firm braking. Rear driving is pointless as the gear and speed will not meet the bedding intent. But a load would.
This morning backing out of the driveway heard a little squeak. My LC now has over 400 miles on it. I just bedded the brakes approximately 200 miles ago. I did run it through a brushless car wash yesterday. This morning I rebedded the brakes again. Hopefully no squeaks tomorrow.Okay I picked up my new LC on Wednesday. Today BoBo has 200 miles on her and I bedded in her brakes like I described above in another thread. Completed ten pulls and my brakes got really hot. It smelled really strong and afterwards I could see the pad material on the rotors. I drove for a while to let them cool afterwards. Went into Trader Joe’s and did some grocery shopping. Came out and could still smell the brake smell when I got back inside. Hopefully she should be good until spring.
I did my usual bedding in process when my LC was new, had zero screeching when backing out of the garage until I was over about 2,500-3,000 miles. Now it does it every time I back out of the garage and sometimes during the day when I’m braking while backing up. Last week I did a few mini re-bedding stops and the screeching while braking while backing out of the garage stopped for one day. Back the next and still here. This problem is ridiculous! Dealer did nothing, still waiting for Toyota to contact me. I like this LC but won’t keep it if they don’t come up with a solution. Seems the hybrid braking allows the rotors or pads to glaze over easily or something unless you drive it hard consistently.This morning backing out of the driveway heard a little squeak. My LC now has over 400 miles on it. I just bedded the brakes approximately 200 miles ago. I did run it through a brushless car wash yesterday. This morning I rebedded the brakes again. Hopefully no squeaks tomorrow.
Edit( I forgot to mention this) I sure am glad I requested for Toyota to not share or sell my driving data. The bedding process would definitely record some hard braking that could be interpreted into riskier driving behavior. An insurer doesn’t know that I’m just trying to bed the brakes.
I hear your frustration and totally get it. If you’re happy with everything else about the LC except the brakes I encourage you to hang in there. Maybe try to rebed the brakes like you did before (you got 2500 miles of no squeaks) and hold out until Toyota issues a TSB or recall. It’s just a matter of time. Make a video of the sound and email it to your service advisor. Get a document trail going and send your emails to Toyota. Send a link to this thread along with it. It’s just a matter of time.I did my usual bedding in process when my LC was new, had zero screeching when backing out of the garage until I was over about 2,500-3,000 miles. Now it does it every time I back out of the garage and sometimes during the day when I’m braking while backing up. Last week I did a few mini re-bedding stops and the screeching while braking while backing out of the garage stopped for one day. Back the next and still here. This problem is ridiculous! Dealer did nothing, still waiting for Toyota to contact me. I like this LC but won’t keep it if they don’t come up with a solution. Seems the hybrid braking allows the rotors or pads to glaze over easily or something unless you drive it hard consistently.
