• Rooftop tent (Ikamper mini)
• Hitch-mount spare tire carrier: 33” OK3 tire, extra fuel+water, recovery boards Maxtrax, license plate with light, etc.
• Side panels with extra fuel / water + shovel/ etc.
• All AC lights: rock lights, bumper light bar, ditch lights, front roof spot lights, side lights, chasing lights
• Control panel / switch panel for all AC lights
• ARB side awning
• ARB built-in air compressor
• Drawer system , fridge slider
I see your side panels are Victory 4X4. Their website says they will not work with OEM rack. How did you make them work? Any special modifications?
Today was mount Diode Dynamic Rock Lights on my Victory 4x4 roof rack. I still need to wire them up but I am 3D printing cable holders so I can zip tie them up.
I have been playing with the idea of putting lights up on my rack. Where do you plan to run the cable from? I have the oem FE rack so running it from the rear hatch in the only option I can find.
Diode Dynamics rock lights use these small cables and they have a 4 way spitters so I am going to run one 3 conductor 16 awg wire from the 4 way spitter down the driver side windshield trim into the engine bay.
12v Powerpole outlet connected to rear battery and fused at 40 amps. (My compressor is a Viair 400P with a maximum current draw of 30 amps.)
View attachment 33399View attachment 33400
Ah! I have the same compressor… i would love to do this. Didnt know this connection format existed. did you just cut off the terminal clamps of the viair and put on a different connector?
Vision Flow wheels with 285/70/18 Nitto Recon Grappler’s. I get a little rub at full lock while backing on an uneven surface but not bad. 275 would’ve been perfect.
Reactions: J44
Yes, cut the Viair cord and crimped on 30amp Anderson Powerpole connectors to mate with the outlet. Added Powerpoles to the removed alligator clamp cords, too, so the compressor can still be used with the alligator clamps.
Where did u order from/brand? Thanks
