Because I have things that will only operate on USB-A that I still like using… two USB QC ports.
Couldn’t find a flush mount dual USB-A port that fit in the space, but I will keep looking and replace this one if I find one I like better.
View attachment 33403View attachment 33404
If you want something that looks more like it came with the truck, you could use this QC3.0 USB dual socket and install 2 or more of them using this replacement switch panel with space for up too 3 additional square (22x22) switches or charge ports. Would look completely OEM.
Added today, Center Console trim cover with side storage. Helpful as not a lot of places to put sunglasses . From StickerFab View attachment 33474View attachment 33473
I got one of these for my wife’s LC, it isn’t actually too bad at all. It cleans up easily too, just throw it in the sink with a bit of warm water, soap and then rinse.
Vision Flow wheels with 285/70/18 Nitto Recon Grappler’s. I get a little rub at full lock on an uneven surface but not bad. 275 would’ve been perfect.
Got any pictures showing the poke? I'm looking at these as an alternative to Method 703's... I can't justify double the price
Excellent looking wheel at an excellent price. I'd go with 275/70/18 though. 285’s are rubbing a bit.
Had a can of Caliper left from previous vehicle, so painted them today.
Today I installed my DD rock lights on the roof rack and wired up the Auxbeam Slim 6. The relay/fuse box wiring was starting to get a little messy and complicated when I wanted to add stuff. I think it all turned out great.
Katzkin thanks to the dealer including it in my deal.
Nice. I was going to do the same put I decided against it last minute. I actually found myself enjoying the clutch seats.
I also notice you’re in the Tomball area. Are we basically neighbors? I’m in the Spring/The Woodlands area.
Not that it’s easy to see. Got the car back from getting detailed and having a ceramic coat put on it.
Now I have to put the rack back on, I do want to run without it right now but the drip moulding pieces for the roof is on back order. So to prevent water from getting in, rack is going back on.
