Toyita forgot a light for rear Cargo Area??
Anyone have any idea on how to add lights for the cargo area? I don’t know how or why but it appears there is no lighting back there as I recently discovered on a dark and moonless night at the campsite. The only overhead lights are the front console map lights and 2nd row. What the heck Toyota?
Looks as if Toyota fixed you up for the 2025 model year.
It has these lights already on either side. They work well enough. LC trim premium.
Curious why you feel that way? They seem to only cover about 1/4 of the cargo area and are also mounted low, when you have items stacked above them, they are concealed.
Maybe OK to illuminate three or four grocery bags but not really enough to illuminate the whole cargo area like a simple overhead light that every other Toyota SUV seems to have to the best of my knowledge.
I just bought an aftermarket “rechargeable” magnetic light… it will work for now….
Could one plug a motion sensing night light into the inverter plug?
You surely could, but would have to turn on the inverter switch to get power to it.
I've installed a USB-C rechargeable "under-counter" light from amazon. It attaches magnetically to a couple of adhesive metal pieces and can be adjusted to 3 brightness settings and even motion activated if desired. OK temporary solution until the OEM lights are available for retro-fit.
Have you guys seen EOD Guys build page? He installed a switch for the hatch courtesy lights. I believe it’s on a FE. I’m not sure if the courtesy lights are on the other trims. I’m still waiting on my non prem LC so I really don’t know.
Thread 'Eod Guy's Ride'
🛠️ Member Build - Eod Guy's Ride
These are pics from his build page.
Added to my watch list. The cargo lighting is one of my biggest immediate pet peeves. I’d prefer them IN the cargo area but would consider on the liftgate. I also want to add a 12v and USB port connections back there.
Does anyone have the part number of the lifgate with the lights?
It should be pretty straightforward to replace it. Just a matter to find out how much it costs.
I use the lights shown here in my home's coat closet, cabinets in the garage, and over my work bench. They work great and have lasted a couple years now. The motion detection works perfectly. Highly recommended. https://www.amazon.com/gp/product/B08FXTTCJX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
