Yea.. they are on the short list for Miss Daisy.I got the Bridgestone Dueler in 18”. They seem like good tires for road and mild off-road, and are pretty subtle in looks (to the point I’ll go less subtle next time…).
I got them because they do well in testing (see Tire Rack - https://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Dueler+A/T+Ascent&sidewall=Outlined White Letter&partnum=76TR0DATAOWL&tab=Sizes) and are only around 40 lbs for the 20” ones.
More subtle than the geolanders or grandtrek? I would use those until they are cashed if they aren’t already cashed.Looking for a more subtle (and not insanely expensive) tire upgrade on 20 inch rims. Thanks for suggestions!
Nice! I did the same on the GX OT wheels. I can’t hear them on the highway, even compared to the OEM Geolanders. I think the ride is less mushy and improves the joy of driving.I got the Bridgestone Dueler in 18”. They seem like good tires for road and mild off-road, and are pretty subtle in looks (to the point I’ll go less subtle next time…).
Those look great - aggressive!Goodyear Wrangler UltraTerrain AT on our 1958
LT275 /65 R18
Those are definitely on my short list to replace Miss Daisy’s OEM Michelins.The best road tire and very light trial tire you could put on is the Michelin Defender LTX MS2.
These really are the best choice if you’re OK with the slightly boring look.The best road tire and very light trial tire you could put on is the Michelin Defender LTX MS2.
Excellent in all categories. Far superior to the Geo junk and Dohlop even are worse.
Mine are 20" factory rims, huge upgrade from the Geo junk, cornering much better, no drifting, no weird feelings when trying to turn tight. I had no idea the Yokos were so bad till i gave them away. The done lops are worse.
Good luck.
I think in general this is correct. I just wanted something different this time.I had the ATs on one of my trucks for a while. The handling is so much better on the MS2s i went back to to those and really pleased on several vehicles including the Cruiser.
275/60-20 Continental TerrainContact, either the AT or HT depending on what you want out of them. Fantastic tire, not inexpensive. Out performs the MS2, which is also a great tire.Looking for a more subtle (and not insanely expensive) tire upgrade on 20 inch rims. Thanks for suggestions!
