- Thread starter
- #21
Hmm the base LC had a 2 wire connector, did you happen to get a photo or anything? You can see the blue/black cable connecting at the bottom of the speaker of the MSW photo above.I took it apart today to have a look, no real added complexity from the camera or other speakers. Looks like the JBL system has a different part # for the woofer (86150-60430), not sure what is actually different than the standard LC system. Did your woofer have a 4 wire connector? If so did you get an adapter to connect to the MSW or splice the wires?
I used the metra 72-8109 wiring harness for all 8 speakers (including the hatch): Amazon.com
I had to trim the spade connectors off the wiring harness and replace with larger ones since the MSW had slightly different wiring connectors
