I have an LC trim non-premium and wanted to upgrade the stereo. Luckily I have a calibrated UMIK-1 microphone to do some comparisons.
First off I wanted to see what was included with the OEM stereo
I found this press release which matches what i found when i pulled the door panels. It is strange they call it a "10 speaker" system, when there are only 8 channels/physical speakers. I suspect they consider the dash speakers as 2 each since they are 2way.
I used a bookshelf speaker wired into each location to try and determine if there were any crossovers. It appears the front door and dash speakers are crossed over around 400hz. These measurments were taken with the same speaker, in the same location, with the same mic, so there has to be something performing xover functions somewhere. Due to this built in crossover, it might not work to use component speakers in the front, you could end up with a dead zone from ~400-2000hz if using just a tweeter instead of the 3.5" dash speakers. The center and rear channels looked mostly flat, and the sub channel in the hatch was low passed to around 200hz (it was hard to measure due to inference from the other speakers). The sub channel was active regardless of the channel balance (front, center, rear)
The sub in the LC trim is definitely active, but only from around 20-100hz.
This is a frequency sweep performed with the mic in the drivers seat. The speaker balance was centered, all the bass/mid/high controls were 0'd, and the sweep was played through both L and R channels and the volume at 25, the bass is pretty hot by default
I plan to upgrade the speakers, but not the headunit or add an amp. From watching the beatsonic install videos, it appears the base LC trim and the premium both use the same headunit (86100-60610) and the 1958 has a different one (86140-60060)
My plan:
Apply Acoustic deadening to doors and hatch: link (done)
Replace Front door speakers with Infinity Reference 6x9 REF697F (since crossed over, the tweeter will be essentially inactive, and 50% the price of component) (ordered)
- Using Metra 82-8146 with extra holes drilled into bracket
Replace rear door speakers with Infinity Reference REF607F 6.5" (done)
- Included brackets fit the door, but need 2 small mounting holes drilled into the door
Replace Side Dash speakers with either infinity reference REF407F (if they can squeeze in) or REF307F (4" ordered, should test them this week)
Replace Center Dash speaker with FaitalPRO 4FE32 (ordered)
Replace Hatch Woofer with Morel MSW 265 (ordered)
- Shallow mount 8", will cut a bracket out of plastic cutting board if needed
Parts:
Speaker wiring Harness: Amazon.com
replacement small clips: Amazon.com
replacement large trim clips Amazon.com
Location | Description | OEM part |
R/L Dash | 3.5" (9cm) Full Range (woofer + tweeter) (4ohm) | 86160-78070 |
Center Dash | 3.5" (9cm) Midrange (4ohm) | 86160-33a50 |
Front Door | 6x9" (18cm) Midrange (4ohm) | 86160-78080 |
Rear Door | 6.5" (16cm) Full Range (4ohm) | 86160-60700 |
Tailgate | 8" (20cm) midbass (2.5ohm) | 86150-60420 |
Amp | 8-Channel class-D | 86100-60610 |
My plan:
Parts:
