Wow thats impressive. Im getting 300-320I still can’t believe the difference in range at fillup with everybody. I get between 370-380 miles and after the first week of the LC, I never got lower than 340 miles till empty
Still not bad…I’m still seeing a lot of people in the 200sWow thats impressive. Im getting 300-320
"Some men are Baptists, others Catholics. My father was an Oldsmobile man."He wasn’t perpetuating a superstition….
Toyota will send gas as part of the roadside assistance that you purchased with the vehicle. Press the red overhead button under the clear shield.I just renewed AAA membership
It is pretty straightforward on pavement and in 95% of the US. But, we travel in situations in which we calculate our fuel range very carefully and usually have to carry a spare gallon or two. So, an accurate readout of fuel remaining is very importantI put gas in it when it needs it, usually down around 30 miles to go. Outside of that, I don't really care. I fill up and it says how far I can go if I maintain consistent MPG, which usually is around 300 miles. Seems pretty straightforward.
My counterpoint to that would be that if you're stuck because of a few gallons of gas, you're doing it wrong.It is pretty straightforward on pavement and in 95% of the US. But, we travel in situations in which we calculate our fuel range very carefully and usually have to carry a spare gallon or two. So, an accurate readout of fuel remaining is very important
Unlikely, totally different platform.My friend just bought a 24 Fourrunner, 2WD, SR5(?). It has a 23 gallon fuel tank. I wonder if it could be mounted on our 2024 LC’s?![]()
Yea.. stupid past late at night..Unlikely, totally different platform.
You'll get used to it, and will eventually be thankful for the heads up. My Tundra can run for about 65 km (40 miles) after the low fuel indicator comes on and it says 0 km remaining, and will still have over a gallon of gas left when I fill up. On the other hand, we had an Audi (or maybe it was a BMW) that when the low fuel indicator came on, you had very few km to empty, and when it said 0 km left, you had 0 km left!There are multiple threads on MPG numbers, regular vs. premium gas, mods for gas tanks. After driving to near empty to remove the wrong grade gas (don't send your teenager to the gas station) I observed that the fuel level display seems designed to create range anxiety. Even with 1/4 tank showing, to me it looks like I'm about to run dry. I may have turned it off, but also did not get any low-fuel warning even down to 30 miles left (when I gave in and filled up). To me, the fuel display is not as effective as it should be, especially in a vehicle designed for driving in places where no help is coming if you run out of gas.
I'm sure I will get used to it, but would like to have a display that doesn't cause me to worry about remaining fuel.
Will be Interesting to see if 300 series or 250 series diesel auxiliary tanks can be made to fit.Yea.. stupid past late at night..
I did that.. filled up the tank with 16.9 gallons, on my initial fill up.
Early on, I had about 300 mile range when i filled up. Now, I routinely have slightly over 350 range immediately after I fill up.
I figured as such.The Distance to Empty will gradually update based on your average MPG.The better MPG you get, the bigger the DTE number gets.
Now we just need to get some of those gas tanks here in the US of A!!!Perhaps mentioned already ... the LC250 model sold in the middle east and other markets with the same T24A-FTS 2.4l engine used on US models, gasoline (not diesel), without the hybrid has a 29 gal tank and gets 25mpg (~700 mile range)
