I Need Help with SwitchPro and Blue Sea Fuse Block Installation
AndrewLucas
9
0
Crestline, Ca
2024 Land Cuiser
Okay, so I’m new to installing lighting on vehicles. I ordered a switchpro and a blue sea fuse block. I’m having trouble comprehending what to do with the wiring into the fuse block. Am I suppose to (for example) run the hot wire from my light bar, splice it with the switchpro button wire, and then wire the combined wires into the positive on one of the Blue Sea terminals, and then wire the negative from the light bar to the negative terminal on the Blue Sea?
I can’t seem to find any videos that make sense to me. All the setups I see are just using the blue sea as a place to connect the ground wire but nothing is connected to the fuse terminals. I don’t get it. Can someone please explain how the wiring is supposed to to be, or if you have a photo or video of your setup, could I see it?
I’m using an 8 button SwitchPro and a Blue Sea ST blade split bus fuse block.
I would have to know the models (links would be great) of the items you purchased in order to see how they are used. I might be able to assist.
After looking around everywhere, I believe the problem is that you don’t need relays and fuses to use a switchpro. I was trying to run it through the fuse block but I guess that isn’t necessary.
I’m using a switchpro 9100 and a blue sea split bus ST blade.
