Horn Swap to Premium horn
cvx5832LC
102
141
CA
LC
Swapped the horn out to something more appropriate to the vehicle’s size. Easy swap, doesn’t even deserve a DIY if I’m being honest. Tip: The pins push in then just pops out, allowing you to remove the access panel to the horns in 30 sec, if that.
The mounting arm on the horn you buy may need to be repositioned to vertical.
Tons on eBay. Get from the highly rated ones as they tend to ship quicker.
If using this one, pay attention to the horn locations. While the high and low look similar, they’re side specific in that the horn will get in the way of proper cable routing if swapped.
