20" Wheel On Prem Package
micah
Jul 5, 2024
64
51
Ohio
Land Cruiser, Tacoma 2017
The 20" wheels that come with the LC premium package have the 265/60R20 tire, which is 10.4" wide by 32.5" tall. Has anyone out there changed that tire out to a 275/65R20 ? That tire size is 10.8" wide by 34.1" tall. Thoughts? Thanks in advance.
I know a 285/75-17 which is 33.8 fits so if anything that probably would also. Even if you have to take a few pieces off.
Side note, the 20s are a stand alone option and not included in the premium package.
If you're considering upgrading your tires (for larger, more aggressive tires), I'd highly recommend getting rid of the (optional) 20-inch wheels and getting a set of 18-inch wheels (Toyota or aftermarket). The 18-inch wheel is the better setup for aggressive tires (higher profile tires, etc.). And as noted above, the 20-inch wheels don't come with the Premium Package (though for many regions, Toyota bundles the Premium Package with the optional 20-inch wheelsโ€”the 20-inch wheels are a forced option with the Premium Package. In other words, it's not easy to find an LC Grade with Premium Package and 18-inch wheels).
20" wheels are not part of the Premium Package. They are a $1200 stand alone option. If you mostly drive highways, they are fine. Off road, the bigger 18" sidewalls are a better bet.
In Canada they are included in the premium pack. You cannot opt out unfortunately ๐Ÿ˜•
Did you figure this out? Iโ€™m wanting to put on the BFG KO3s in LT275/65R20
Have not decided yet. I like the KO3s also. Too many tires ๐Ÿ›ž to choose from.
I installed the 275/60 R20 SL Mickey Thompson Baja Bossโ€™s AT and they fit perfectly and the spare also just fit. Another great option and they do well in the snow.
Looks awesome!
Did your mpg take a hit at all with the Bajaโ€™s? What do you think of them so far?
I put on Pirelli Scorpion AT+ in 275/65/20 ... LOVE THEM!
Love them, several other people I know also put them on after seeing mine. I did a Wescott lift kit and the tires and full skids and still running around 22 to 23 mpgโ€™s. Thought I was going to take a heavy hit but they are the SL versions. Iโ€™m about 1 mpg less with both.
Any chance youโ€™ve decided? Looking to get 275/60R20 tires as well. Even wondering if 285s would fit without lift.
I decided to finally get the 275/60R20 tires and really like the choice.
