20" Wheel On Prem Package
micah
63
51
Ohio
Land Cruiser, Tacoma 2017
The 20" wheels that come with the LC premium package have the 265/60R20 tire, which is 10.4" wide by 32.5" tall. Has anyone out there changed that tire out to a 275/65R20 ? That tire size is 10.8" wide by 34.1" tall. Thoughts? Thanks in advance.
I know a 285/75-17 which is 33.8 fits so if anything that probably would also. Even if you have to take a few pieces off.
Side note, the 20s are a stand alone option and not included in the premium package.
If you're considering upgrading your tires (for larger, more aggressive tires), I'd highly recommend getting rid of the (optional) 20-inch wheels and getting a set of 18-inch wheels (Toyota or aftermarket). The 18-inch wheel is the better setup for aggressive tires (higher profile tires, etc.). And as noted above, the 20-inch wheels don't come with the Premium Package (though for many regions, Toyota bundles the Premium Package with the optional 20-inch wheels—the 20-inch wheels are a forced option with the Premium Package. In other words, it's not easy to find an LC Grade with Premium Package and 18-inch wheels).
20" wheels are not part of the Premium Package. They are a $1200 stand alone option. If you mostly drive highways, they are fine. Off road, the bigger 18" sidewalls are a better bet.
In Canada they are included in the premium pack. You cannot opt out unfortunately 😕
Did you figure this out? I’m wanting to put on the BFG KO3s in LT275/65R20
Have not decided yet. I like the KO3s also. Too many tires 🛞 to choose from.
I installed the 275/60 R20 SL Mickey Thompson Baja Boss’s AT and they fit perfectly and the spare also just fit. Another great option and they do well in the snow.
Did your mpg take a hit at all with the Baja’s? What do you think of them so far?
I put on Pirelli Scorpion AT+ in 275/65/20 ... LOVE THEM!
Love them, several other people I know also put them on after seeing mine. I did a Wescott lift kit and the tires and full skids and still running around 22 to 23 mpg’s. Thought I was going to take a heavy hit but they are the SL versions. I’m about 1 mpg less with both.
