17" SCS F5 wheels installed
Are the Bradley's hub centric like the SCS wheels?
Hub on the Bradleys is 110... which is causing some 'issues' finding the proper hub centric rings, as the ones I have found so far all have a little 'lip' that protrudes on the wheel. I have had a few people say that the wheels are high enough quality that they can be used as lug centric, but I would still like to find the proper rings. One company on Amazon has offered to make custom aluminum ones for $50 Cdn, as opposed to the stock offerings at $25. (and plastic at $12) I could just try and sand down the plastic ones I bought, but then if that doesnt work the custom ones just cost me $10 more.
Sounds like a lot of work. I think I will pass on the Bradleys. They look great and I had the F5 wheels on my 4Runner but the Stealth Custom Series wheels were hub-centric so I never had an issue. To bad they don't make a +45-35ish offset wheel. I'd consider running them on my LC if they did. Good luck on your quest for the proper rings.
So finally available. I am wanting to place an order for SCS F5 matte gunmetal. Just want to make sure these will fit and are hub centric. Can someone confirm all this is proper sizing?
17 x 8.56 x 139.75.50"/+2095.121.5 lb
Got my custom hub rings today, fit 100% perfectly on the Bradley Wheels. Super impressed as they were a vendor on Amazon.
Just got these SCS F5 17x8.5 but they look different like its missing step. Am I right ?
These are ones I got:
This is how it looks on their website. and another install:
You just send them a message with what you are looking for and purchase the Amazon listing. He sent a complete drawing with the approriate info.
Basically you need: 95.1-110mm in a 7mm depth (Stock is 10mm) I attached the photo they sent (This would be specific for Bradley Vs)
how did you contact them.. im not seeing a way to message them from amazon unless im blind lol..
I believe I went through the 'ask a question' /Rufus chat but I believe you can also just buy and they contact you for the sizes.
