Thoughts on initial low mileage oil change at dealer to minimize metal wear break in debris affecting long term maintenance .Have rread pros and cons and heard stories of lo mileage changes showing serious debris.
This IS helpful because it was tight, I used that exact wrench) (I was afraid of โcrimpingโ the new filter during the tightening.) so I was thinking of getting one of the other wrenches that ppl put on here .It was a BEAR to refil oil because of issues with funnel andโฆ I was using the 5 quart container. I didnโt have the one quart, I have learned from that mistake and I will be buying a few one quart for next time .. especially if I canโt find a good funnel -I see a lot of ppl used those for funnel.I just did mine yesterday. 1400 miles.
Two things to note:
1. The oil filter was on there tight. I had to go out and buy a wrench to remove it.
This one did the job easily.
2. When refilling the oil, you will NOT be able to get a standard funnel in there. You'll need to buy a threaded funnel (I don't have one, so I don't know the correct size) or use an oil container as a makeshift funnel (3rd pic in the post below).
I just did the first oil and filter change after break-in @ 1,000 miles. It is one of the easiest to change. Everything is easy to access. The skid plate has 6 12mm bolts. 2 of the boltholes are key holes so you just loosen them and it will hold the weight for removal/install. Once you have the...www.landcruiserforum.com
Amazon for the funnel, search for "Toyota Oil filter wrench kit"This IS helpful because it was tight, I used that exact wrench) (I was afraid of โcrimpingโ the new filter during the tightening.) so I was thinking of getting one of the other wrenches that ppl put on here .It was a BEAR to refil oil because of issues with funnel andโฆ I was using the 5 quart container. I didnโt have the one quart, I have learned from that mistake and I will be buying a few one quart for next time .. especially if I canโt find a good funnel -I see a lot of ppl used those for funnel.
Same. I only had 5 quart jugs on hand and it was a pain to refill the oil.It was a BEAR to refil oil because of issues with funnel andโฆ I was using the 5 quart container. I didnโt have the one quart, I have learned from that mistake and I will be buying a few one quart for next time .. especially if I canโt find a good funnel -I see a lot of ppl used those for funnel.
