TPWS Tire Pressure Warning System - Setting By Specified Pressure
jdchiarella
13
22
Ventura, California
2024 Land Cruiser
When I go into vehicle settings/TPWS and I select " Setting by Specified Pressure" I get the screen that shows "33" as pressure for front tires. The manual states on page 559-560 that this is user adjustable., but I can get it to change using buttons as usual. See paste of manual instructions below. and pics of screens displayed Anyone figure this out yet? Thanks in advance.
1 Start the hybrid system.
The tire inflation pressure cannot
be set while the vehicle is moving.
2 Select on the multi-
information display.
3 Select “Vehicle Settings”.
4 Select “TPWS Setting”.
5 Select “Tyre Pressure Set-
ting”.
6
Maintenance and care560 6-3. Do-it-yourself maintenance
6 Select “Setting by Specified
Pressure” and then select the
desired front and rear tire
pressures.
7 Select “Yes”.
The tire pressure warning light will
slowly blink 3 times.
After setting the tire inflation pres-
sure, a message indicating that set-
ting has been completed will be
displayed on the multi-information
display.
Why are you changing it? This value is the baseline used to determine if a low pressure warning is triggered. For example, if the actual measured pressure is 28 psi, (33-5) you will probably get the warning.
I’d like to adjust as well for airing down. Considering not using in the summer. The warning was really handy when I got a sidewall tear. Gave me just enough time to find a level spot to change tires.
Have you tried to change the setting and see if it is user definable?
