Front "FE" skid plate: PT228-60242 Trans Skid Plate: PT228-35241. I think if you look at the Toyota website for the 2025 LC, and then look at options or accessories you can also find them.
Find another dealership..My dealership is insistent they’re incompatible lol
These skid plates are now port installed options for MY2025.I think (don't know) the LC/LC and 1958 come with debris covers for the front and Xmsn and they are kinda flimsy. The 1st Edition comes with a front skid plate that covers the Xmsn and a second one that covers the Xfer case.
I did it without ramps, and it was admittedly a bit of a PITA, but doable.thanks
They seem easy enough to install if I can find somewhere to act as a ramp
I mean if I put the FE front plate in only (part 60242), might I be able to install the trans skid of, say c4 fab in the future and then further down the line upgrade the front skid
Wow, I just might look into fabricating a reinforcement plate for that area.Whilst installing my skid plate, wouldn’t ya know…. Noticed my Radiator bracket is bent
Clever, though admittedly I worry about the welds breakingIf you're looking for a way to unbend it, Wrap a chain around a 4X4 (or like item) and drive the front tires on top of the 4X4, creating an anchor point. Attach a pulley on the chain so that the pulley is right below the point of where you want to pull down. Run a cable through the pulley and attach it to the point you want to pull down. Gently start pulling the cable ensuring the metal is being pulled in the direction you want.
Is there anything that you can’t do EOD Guy?Wow, I just might look into fabricating a reinforcement plate for that area.
I am also looking to have some kind of steel reinforcement fabricated that will attach to the recovery points; guess I should have just gone with one of the aftermarket’s and waited. Wasn’t keen on not even having a debri shield thoughIf you're looking for a way to unbend it, Wrap a chain around a 4X4 (or like item) and drive the front tires on top of the 4X4, creating an anchor point. Attach a pulley on the chain so that the pulley is right below the point of where you want to pull down. Run a cable through the pulley and attach it to the point you want to pull down. Gently start pulling the cable ensuring the metal is being pulled in the direction you want.
