Towing "Pre" Test
ferrari1898
57
81
Charlotte, NC
2024 Land Cruiser w/ Premium Package
In a couple weeks we will be camping in the Smokey's and will have a more extensive towing review. It's a 2.5-3 hour drive from Charlotte to the Smokey Mountains and it is a route we have taken with our two previous tow vehicles. It is also a good mix of with some city, highway and interstate along with a combination of flat, hills and mountains.
Today, in preparation I a little 20 mile loop from the camper storage to downtown York (rural suburb of Charlotte). The route is 45-55 mph with a couple stop lights and gentle hills with a small section in the city at the half way turn around point.
We have a Hitch 17BHS that is 7' wide and weighs 3300 lb / 425 lb on the tongue. With some of the gear we are likely closer to 3500-3600 lb. We have a weight distribution hitch, but debating if the additional weight and effort is worth the trouble. With a standard hitch, the Land Cruiser felt pretty stable, though I did not have any jacked up pickups / big rigs blasting by me.
The first run I did without the camper, and in the standard drive mode. It took me 26 minutes to complete the 20 mile route and I averaged 27.3 mpg while using the cruise control.
The second run I enabled the towing mode. It took a few minutes to figure out how to setup the brake controller (vehicle setting that you access with the steering wheel controls). It took only 24 minutes to complete the course while averaging only 12.2 mpg. I was hoping for something a little bit better, but there was no lack of torque and in towing mode the gear selection was spot on. The integrated brake controller was wonderful (I had gain at 7.0) and so much smoother than the previous aftermarket controller that plugged into the Honda. When the 7 pin connector is plugged in (not sure if this applies to the 4 pin) the cruise control is disabled. The engine also does not shut off, even at the stop light. I also noticed that at low speeds the electric motor was less inclined to engage.
The third run I had the camper and disabled towing mode (using the standard drive mode) in hopes I could use cruise control and get betting mpg with the engine shutting off. The brake controller still functions like in towing mode though the cruise control still does not work. In this run it took 24 minutes with 11.4 mpg. While the engine shuts off at the stop lights, and down some of the hills to save fuel, the Toyota opted for turbo boost instead of downshifting which on several hills it struggled to maintain speed.
A couple final thoughts on the initial towing test.
1 - When connecting and disconnecting the camper I disabled the towing mode. The engine would shut off, the a/c would still run while lining up and performing all the house keeping when going in / out of storage.
2 - If you manually use the brake controller, there is a message that appears in the center of the dash which is really nice to perform a brake test.
Very informative post, thank you very much!
Nice write up. I’ve been wanting to test this out. My trailer is a 13’ scamp that does have brakes though it weighs around 1,500 pounds 😂
I have a teardrop just under 3k lbs.
2021 4Runner pro would not pull it over 60 without dropping into third gear. Land Cruiser sitting around like it’s nothing. at 50 Land Cruiser gets about 12 miles to the gallon while were 4runner was getting about seven.
And quite honestly, the ride is way smoother with the trailer.
You must not live at altitude. Spend almost all my time in second and third gears, I am over how poorly the 4Runner tows here in CO, and can't wait for delivery of my LC.
Sorry to hear, but that makes me feel not alone. Just some hills but mostly coastal plains.
Are you running a weight distribution hitch or just straight hitch mount?
I am looking at a rv trailer @ 2500 lbs with brakes.
I get about 11 mpg towing 2.5k tear drop.
Your experience is pretty much the same as mine, however I’m only getting about 11 miles per gallon. Yet to think that I need more torque. I did have to put a anti-swaybar on the trailer and hitch at high speeds when the road got lumpy. The trailer would get really swirly, with the sway bar don’t even think about it being back there..
