Yes.Do the tabs for the smaller cover hook into the same spot?
Old post, however, I just finally received my LC. What is the easiest way to remove those two tabs underneath the hitch cover? They don't seem to want to release easily. I must not be doing something right. Thanks.I removed the tow hitch cover and put on the smaller cover with a hitch. Tip when you remove the cover there’s 2 tabs underneath that you should remove first and then pull it off.
Yes, that is surprising they don't mention these lower tabs. If one were to follow the manual and pull too hard, you could tear the bumper cover.Thank you for this. I had no idea a smaller cover was hidden in my storage behind the seats of my vehicle. I looked at the manual about getting the big one off, and there's zero mention of the tabs on the bottom.View attachment 15825
small flathead screwdriver. Separate base from round flat pin head.
I can't remember if the small cover came with 2 push pin connectors or if I reused the ones from the big cover ... but yeah it looks good with the small coverThank you for this. I had no idea a smaller cover was hidden in my storage behind the seats of my vehicle. I looked at the manual about getting the big one off, and there's zero mention of the tabs on the bottom.View attachment 15825
Dang that's pretty cool! I just added the Reno Hitch Slider, which I like the look of, and the price of, but the added coverage of the RR is pretty sweet.Anyone use this Rugged Ridge slider, tempted to give it a try…
View attachment 18669View attachment 18670
For anyone with a 1up bike rack - i used a wheel lock as my hitch pin. I emailed them to ask about this and they said that it is the same pin just longer so that should be perfectly fine to use as a hitch pin.
Do you have a photo or link of the wheel lock?
Just discovered the hitch pin for both my 1up and a new Reno shackle hitch are too short. Don’t order the shackle with it, you’ll save yourself $10. Amazon.com
Thank you for reaching out. We have started to see thicker hitches like this with Toyota. We are not sure why they are making them thicker like this. If you would like you can use a longer pin, like a wheel lock pin. 1/4 Turn Replacement Pin
Yes, I got the standard large cover and the half cover was in the Land Cruiser when I purchased it.That looks so much better! Did the smaller cover come with the vehicle? I wasn’t aware of any other cover aside from the big main one.
Did you look in the storage compartment behind the rear seats?Mine didn't come with it. Anyone have a part number? Thx
U mean in the trunk under the rug? I check there and didn’t see. I didn’t know there was a compartment behind the rear seats tooDid you look in the storage compartment behind the rear seats?
My pin was in the glove box.U mean in the trunk under the rug? I check there and didn’t see. I didn’t know there was a compartment behind the rear seats too
I have the pin. I’m talking about the cover that go above the tow hitchMy pin was in the glove box.
