Switch panel removal (Dvr's side)
EOD Guy
1,618
1,802
Alabama
To remove the Dvr's side switch panel you will need a #2 phillips and a 10mm wrench and most of all don't be scared.
All the bright colored wires are not OEM wiring, I'm in the process of installing some switches etc.....
Under dash 1 - Yellow dots are bolts/screw, Red dots are tabs.
Under dash 2 - Door weather stripping must be pulled away 1st (Yellow dots) then the side panel can be pulled off (yellow dots are approx where the plastic clips are, the Blue dot is a plastic hook that must be inserted 1st when you reassemble.
Under dash 3 - Pull straight out on the switch panel for removal.
