REI Trailgate Sleeping Platform
supraphonic
๐Ÿ“› Founding Member
Jul 21, 2024
27
76
San Diego
Quick take based on about five minutes of driveway experience and zero nights. Not sure this is the perfect solution for my use case, but it's promising.
1725239384528-png.10360
Came across this product while looking for removable sleeping options to make up for the lack of a flat floor. This isn't a full time overland rig for me and I don't need to run a 24/7 solution, but with my search and rescue volunteering it's not uncommon to get a 10pm callout for the following morning two hours away in the mountains or desert, or to have an evening search suspended and be picked up with daylight, and it would be great to have something I can have set up ready to go for a quick crash in those situations.
It comes with a replaceable set of front legs for SUV use that are supposed to fit in the rear seat footwell, as well as a level set for pickup use, and can stow away in a case when not in use.
In implementation with the J250 it's not bad, with one notable caveat being the leg positioning. I did need to bump up the front passenger seat a hair up from my wife's usual position, but everything closes up with the platform set up.
The front brackets are wonky around the transmission tunnel โ€“ I kept the center one at its lowest setting and had to crank the outer one to compensate, and the two rearmost brackets needed to be fully extended to keep it close to level with the boost the transmission tunnel was providing, and even then I'm still not sure the middle set of legs makes contact without my weight in the cot. I really don't love that it's resting on plastic trim, and I'd want to get some kind of rubber or fabric in between there for actual use. Grateful for the high ceiling because it's pretty cozy for me maxed out that high, but in exchange there's a healthy amount of space underneath for storage.
The foam topper so far is nice enough but I'd probably still want to run with with my backpacking sleeping pad. If this is a keeper, I'll very likely just take a pipe cutter to that front center leg to drop down the height past its lower limits and get everything else evened out.
Good Labor Day deal โ€“ definitely nothing fancy, but not a bad plan for a quick base camp.
Link: https://www.rei.com/product/229077/rei-co-op-trailgate-vehicle-sleeping-platform
Interesting. Did you get 40โ€ versus 32โ€?
Looks like the legs could be modified to lower it substantially (with the 60 seat removed)
Very possibly. The rear legs could probably drop another 3 inches or so without needing to clear the rear seat, but the limiting factor is really the transmission tunnel, that leg is completely bottomed out and everything else had to be raised to compensate.
It's several pieces once it's disassembled and a bit of a pain to pack back up again so I'm waffling a bit on whether this is actually something I'll realistically get use out of now. Grateful for REI's return policy allowing me to sit (sleep?) with the idea.
I just ran across this same possible solution and was wondering if you have any more experience with it as an update?
Also, at the REI site it says:
"In the vehicle, system can be left fully deployed for quick access to a good night's sleepโ€”or partially deployed ("in half") for use of back seats or cargo area storage space "
Is this easy to do?
Thanks for sharing your experience
Thanks for sharing this product, its interesting as an idea but if its difficult to fold up then its kind of a no go. I'm currently looking at the trunk-mate as an option, or maybe even just building one. I generally have been a hammock camper all my life so car camping will be new.
I have found non-slip shelf/drawer liner to be endlessly useful to protect finishes while providing grip and also helping to stop rattles between plastic crates on rough roads. Very cheap on Amazon or Walmart. Just cut out whatever size shape you need.
