PSA: Loose wingnuts in rear arches
cvx5832LC
180
254
CA
LC
Cleaning the LC today and chanced upon loose (untightened) plastic wingnuts on both rear arches. These are the ones that hold the insulation in place. All nuts on both sides were not secure, although none were missing. I suspect the insulation taking a set, or not being tightened properly at the factory, which is not likely. I've also posted my option sheet. If this is a case of something that had to come off when my vehicle went through port-installed options, I can't see it.
Tip: If yours ends up being loose as well, don't forget the ones closer to the lip (x4) as they're hidden from view. No tools needed. "Finger-tight" was the only spec I used.
Thanks for the info. Checked our FE and found the same condition - Hand tightened and will keep an eye on it.
Thanks! I'll have to check that out! If you find they loosen up again, I'd suggest putting a dab of RTV at the bottom of the stud (closest to the body) then tighten the plastic nut. That should keep the nut from rotating and easily overcome if you ever need to remove them later on.
