Part# for this trim piece
handy
117
84
Texas
FJ and LC
Does anyone know the part# for this trim piece? I guess it was loose and flew off and I just saw it this morning.
Does anyone know the part# for this trim piece? I guess it was loose and flew off and I just saw it this morning.View attachment 19160
Following. Had you taken it off before? or just flew off as is from factory? i took mine off to install the nashfabco ditch light brackets and they simply don't go back in tight. Even mechanic tried and broke one of the white clips. I have them on now but not very tight. someone needs to develop a third party replacement.
Just what the doctor ordered! Mine flew off somewhere in the Mojave desert after breaking that tiny yellow clip while installing the HAM radio antenna. :(
For anyone who still has the trim but broken or lost yellow fastener, since the dealerships have this simple plastic piece (and any other LC parts) on back order for months, I believe this amazon solution should work: Amazon.com
One of these two should be a suitable replacement. I discovered that it should be placed into the trim first, not the hood body. It snaps out of the body from the back with pliers to compress the prongs.
Mine just flew off and noticed the other side is not super tight.
I will need to take them off when my ditch brackets come on also.
I just ordered 4 different types of fasteners.... from "bamwholesaleparts.com" no issues getting them.
  • LC Plastic fasteners.pdf
Unfortunately the Amazon clips don’t work and the cowl edge trim replacement the includes the yellow clip is even back ordered on BAM.
I received the part today and attached is a good view of the bottom. I just realized the small yellow clip is still attached. In the zoomed in picture the plastic hole the clip goes into looks thick on the edges, but with the naked eye it looks very skinny and fragile. I am guessing that edge piece cracked and the part then flew off. We have had a lot of high wind gusts here the last few weeks.
If you do a search of the part there are several dealers around the US that have them in stock. My local dealer didn't and they said it was on back order for 2+ months. They can also do a statewide search for you.
