No Footwell Lighting? No problem. Plug and Play add-on.
StickerFab
🛒 Supporting Vendor
Jul 21, 2024
85
158
Fort Myers Florida
2024 LC
Our Land Cruiser non-premium package didn't have footwell lighting which was a bit surprising. 1958 doesn't either which is a little less surprising. I checked the factory plug I found that was taped up and not in use on the passenger side. Couldn't get a voltage reading from it. So started asking around and searching for kits. Pretty happy with the outcome.
PURCHASE HERE: OSD OE Style Footwell LED Lighting Kit - 2024+ Land Cruiser
INSTALL VIDEO:
If you have premium with the white lights, couldn’t you just disconnect those and add these since the wiring is already there? Or would that not work? Could you post a photo of what the light and wiring look like before install?
  • Thread starter
  • Moderator
  • #3
Pretty sure the connectors are not the same size as these. I'm not at the office right now but you can compare the glove box led connector to the footwell led connector...
