Lift & leveling kit options
I'm curious, is there a simple preload levelling kit that simply "levels" the LC? That would be a 1"-1 1/4" lift upfront only. Thanks
Readylift has a 1" front for around $200. Fairly simple install, but will require trimming down your factory strut studs.
That looks like a tophat lift. I'm specifically looking for a preload lift which Readylift makes but for 2.5" upfront.
That's correct... I see where you said pre-load, but you'd have to sweet talk RL or Westcott (or similar) to see if they would sell you just the collar. I thought about machining down Wescott's collar because I like the under spring placement better than RL on top. Not sure it matters, but none-the-less ended up with Dobinsons.
It's hard for me to understand this desire to level the truck because as soon as you load some stuff in the cargo area the rear will sag and you will feel like you are on a speedboat with a view of the sky instead of the road... Much better to have a bit of rake towards the front in my opinion.
Mine sits dead level now with my homemade platform, recovery gear, etc in the back. I wouldn’t mind lifting both front and rear about 1-1/2” or so. Haven’t seen anything to accomplish this.
Want more rake with your baller shocks setup? Swoop up some 2022+ tundra rear springs from FB market place for cheap!
I have looked at all of the pics on this site an can not meaningfully see a difference between the vehicles with the level kits and stock. I am sure they make a difference when going big on tires but for those of us upsizing tires for looks and not function (i.e. 31s vs 35s) is this upgrade meaningful? Not about cost but purely changing the stance of the vehicle.
I have a similar sentiment.
Can anyone (perhaps you winnrider if you've gone down this rabbit hole) provide best lift/level kits + upsize tires for someone who cares more about looks than function (90%city driving)?
shock setups look sexier than lift spacers bro. With the wheel well gap u can’t avoid looking at the suspension package. It’s like like wearing gray sweat pants in the winter 😆
I settled on Ko2s 33s (275/60/20) no lift/spacers. I’m in the woods every week and no issues. When I upgrade it will be full on suspension. The spacer lifts look pretty labor intensive for no perceivable difference in stance. Now if I was a rock crawler, totally different approach. Put some chunky shoes on that girl and you will be a ok. Did 400 miles to Florida and it rides like a town car.
