🛠️ Member Build LC79 GreyHound Build
Member Build
greyhoundlc79
20
17
Kuwait
Lc200, Lc79
Working on my LC79 monthly build and updates so will share what we have from start to finish as I Progress.
All progress pics reels and vids and mods on my Instagram account: @greyhoundlc79
Will keep updating here as well.
First pics of receiving the LC79 at the local Dealership.
First trip was to the local body PPF protection by Cartech.
I opted for may finish protection.
2nd Trip had to replace the stock rims and tires with the BFgoodrich and Method Wheels.
3rd Trip after waiting for 4 months finally the rear canopy arrived and was installed.
Canopy Bushtech
From here, everything is installed by myself on the weekends or when I have the time to do so.
Rear Bumper install with spare wheel carrier and Jerry Can by AFN
Yet another trip, this time for the suspension install as I dont have the gear to do them, but I bought them abroad and installed them locally.
Suspensions are Dobinsons MRR 4 way adjust.
Font and back.
The before and after difference in ground clearance
Before
After
Back wrenching this time round front bumper replacement.
IronMan Raid Bullbar with a 12000lbs winch
Rear bed truck installed wooden floor and side decks all sprayed with Rhino Linning for custom fitment of items.
Now started working on the rear Control Panel Board want to save rear bed truck space so decided to piggy back it on the front rear panel of the canopy.
As I did not like the idea of the airbag system components being under the car for maintenance or future leaks from dirt and debris decided to do some customer designs on Fusion 360 and print the brackets relevant to the height of air lines and system.
Noticed the airbag was sitting way to close to the exhaust pipe for my liking added some additional heat shield.
Also the stock shield with the elbow air connect was just not going to work so I had to add a straight fitting instead of the elbow.
Needed a way to get the main 2AWG wire from the main battery to the inside of the canopy, as I dont like drilling holes in the body of the vehicle, decided to sacrifice one removable back panel with 4 small holes 2 large for the 2AWG wire and 2 for the airbags Left and Right, also needed a way to seal the entries from dirt and dust getting inside the canopy.
So decided to design a pass through.
