LC250 Rock Sliders List
+1 for adding OEM sliders to the list. I’m leaning towards those because they’re minimal and low profile and can be had much cheaper than the others, especially during a 25% off parts sale.
With this, and the one other brand (Westcott) where they want you to drill holes in your frame, it feels like maybe they wanted to just reuse an existing design maybe, and didn't realize something didn't quite fit?
I think one of Westcott's YouTube videos mention drilling is optional for more sturdiness. Not necessary. It was a comment reply.
I ordered CBI through yotagarage...suppose to be about 6 weeks. It's been delayed by CBI.
Well I currently have a set of RCI 5 degree and CBI without kickout in my garage so thought I’d give some thoughts and comparisons.
Fit: CBI are wider. From frame to outside edge is 15”. RCI are about 14” for the front and 16 or so for the kickout. Both make acceptable steps but CBI are a little wider for the front passengers. CBI are also 4” longer front to back (70” vs 66”). So for back passengers, the no kickout, CBI might still be a better step. They both sit at about the same height. Removable top plate on RCI vs welded on for CBI.
Design: I can’t really decide which I like better. Personal preference but I think both look good.
Finish: both are quality builds, nice welds, quality material. RCI are powder coated and seems very high quality, nice texture. We’ll see how it holds up. CBI are raw (I usually prefer to rattle can for easy touch ups).
Install: CBI are much much easier to install. Better requires drilling or cutting. RCI uses a channel and a few extra bolts through the frame. Probably a little sturdier? However CBI seemed to be very stout when mounted.
Price: RCI are cheaper and customer service has been top notch. CBI had a lengthy lead time and I haven’t dealt with customer service so can’t comment on that.
I decided to keep the RCI sliders but really was 50/50 on which to keep. Let me know if you have any other questions. CBI are still up for sale! Located in Cheyenne, WY if anyone’s interested.
Does the RCI connect to the body instead of the frame in the back?
Compiling a list of all the rock sliders available on the market today (03/25/2025). Brand names with hyperlinks. If anyone has them installed and have an unbiased reviews on them, please share below in comments. Pictures of them on your vehicle would be great as well!
Dissent Off-Road
CAtuned Off-Road
C4 Fabrication
RCI Off-Road
DV8 Off-Road (They call it Side-Steps, not sliders)
Greenlane Offroad
NYTOP
CBI Off-Road
Victory4x4
SLEE Off-Road
Westcott Designs
Leave in comment if I missed any.
Onyx,
Also add BudBuilt slider, Bud had been making armor for Toyotas for forever. Definitely top end for performance, strength and craftsmanship. Can’t review them personally, I’m still shopping. BudBuild Sliders LC250
From Greenlane:
Thanks for reaching out. Our landcruiser sliders weigh 24lbs per side, for a total of just under 50lbs for the pair with hardware. They mount fully to existing holes and do not require any modifications. They are rated to support the weight of the vehicle from both side and bottom obstacles, but we do not recommend using them as a jack point. Luckily, the LC has plenty of accessible jack points already!
Updated a whole bunch of info directly from these vendors. Check out post #1 of the entire thread. Will continue to update once I receive more info.
I honestly can't imagine cutting the trim of my vehicle just to install sliders! I'm not sure the reason as to why this should be necessary, but perhaps they should update the design so it is not necessary.
As someone I know always says, different strokes for different folks. A few reasons, it’s tuck and flush, max clearance and eliminating that common gap, which means it doesn’t stick out as far, less overall material, thus resulting in 88lb total for the pair. Hard to beat that weight.
It’s not for everyone, and that’s perfectly ok. That’s the great part about having an aftermarket support that you can pick and choose from.
The trimming part isn’t any different than trimming for front bumper, rear bumper, fitting larger tires, etc.
Attached is the gap I’m taking about as a reference.
Attached is the gap I’m taking about as a reference. View attachment 32453
Which brand sliders are these? Give us a brief review please.
Those are CBI. I posted some comments on them above comparing to RCI. Also have them for sale. As he says there is a bit of a gap. Same as the RCI. But they are beefy! I ordered two sets to hopefully have at least one before an upcoming trip. Sadly both were ready at same time and I couldn’t cancel one.
The photo is just a reference of the gap I was referring to as a response to why CA Tuned Offroad decided to have a flush style rock slider to maximize clearance, reduce the overall size which means less overall weight compared to other brands. 88lbs for the pair compared to others that weigh 125-200lbs. That’s all. Hope that makes sense.
There are a couple people who have installed them without cutting the trim piece as well. FYI.
Here’s a side by side comparison.
Here’s a side by side comparison. View attachment 32462View attachment 32463
Do yo know what those did different so they don't have to trim the plastic trim pieces?
The flush look definitely look nice.
Man, I'd like that RCI if it was the width of the kick out portion, but all the way to the front. A lot of these have some real goofy looking decks, if you want to use it as a step too. I'd like some that look like Tremor/Raptor running boards, the Gohino look good, but I have heard bad things about their quality. I know, not rock sliders.
*I don't like the deck of the CBI. I like the deck of the RCI.
