Horn Upgrade
Anyone else disappointed with the factory "meep meep/roadrunner" horn?
I replaced mine with the OEM Toyota Premium Horns. The kit comes with two larger horns. One 500 Hz & one 400 Hz.
Very satisfied and easy to install.
Just Google or Ebay search Toyota Premium Horn.
Good Luck
Does it all bolt-in on the same hardware and use the same wiring harness?
Yes, was able to use existing bolts and connectors. Did not need the wiring harness that came with the new horns. Easiest upgrade I've done so far. 8 plastic clips to remove plastic cover to access horns and 2 bolts, 1 per horn.
Received mine today and the install was super easy, but they seemed DOA! Nothing, silencio! I noticed the bracket was off center and I needed to slightly rotate the bracket to get them to install with the horn opening pointing downward, but the harness was plug and play... and nothing. Re-installed the old "meep, meep" horns and will reach out to the eBay seller. Seem legit OEM Toyota, direct from Japan.
Was looking to do this, but wanted to check with the "experts" to make sure it was a good idea. :)
Found it on StickerFab (link on this site - I assume it's affiliate).
They have a Black Friday deal, so 10% off.
Help the forum; help a small business. Sound premium.
Win-Win-Win
Honestly, I was underwhelmed by the Toyota premium horn upgrade. It is slightly better but still feels lacking. Seems like if you want to do an upgrade, it should be to something even louder/fuller.
