I had the year 1 5th gen 4r also. Dinky little horn, kinda funny, think I will keep it in.
Does it all bolt-in on the same hardware and use the same wiring harness?Anyone else disappointed with the factory "meep meep/roadrunner" horn?
I replaced mine with the OEM Toyota Premium Horns. The kit comes with two larger horns. One 500 Hz & one 400 Hz.
Very satisfied and easy to install.
Just Google or Ebay search Toyota Premium Horn.
Good Luck
Yes, was able to use existing bolts and connectors. Did not need the wiring harness that came with the new horns. Easiest upgrade I've done so far. 8 plastic clips to remove plastic cover to access horns and 2 bolts, 1 per horn.Does it all bolt-in on the same hardware and use the same wiring harness?
Thanks for sharing this link. Will definitely be replacing the clown car horn with this one. CheersThanks but to be sure I get the correct horn kit, would this be the one? JDM Toyota Land Cruiser J202 Premium Horn Genuine OEM for sale online | eBay
You’ll need to go into the DID (Driver Information Display), scroll to the gear "settings" and select lowrider.If I’m upgrading my horn it better be able to play La Cucaracha.
Ahh! I missed that page in the manual!You’ll need to go into the DID (Driver Information Display), scroll to the gear "settings" and select lowrider.
Finally received my horn. I’m just hoping that someone has had good luck installing it. My instructions are in Japanese so I’m going to take a swing at it here this weekend and hope it sounds better when I’m done lolThat is the kit I purchased.
It's literally a ten min job. 12mm ratchet.Finally received my horn. I’m just hoping that someone has had good luck installing it. My instructions are in Japanese so I’m going to take a swing at it here this weekend and hope it sounds better when I’m done lol
Just shared my install. Sounds much better.Someone please post a video/soundclip of the "premium horn"
Yup! Went much smoother than I had imagined it would.It's literally a ten min job. 12mm ratchet.
