Can you share the part number for the bronze center caps?I did re-use the lug nuts from the stock 18" wheels, and I ordered the bronze "TOYOTA" caps, which are perfect with Trail Dust.
Can you provide the link? Is this a dealer specific site, or simply the Toyota site? I really like these wheels and would like to order a set while on special.FYI Toyota has a 25% off special for parts, and some dealers have their own discount.
I ordered the TRD Wheels off the Toyota Parts site and got them for $711 for a set of 4.
I believe I’m looking for this exact setup. I really like these wheels and want to stay close to stock on the tire size (265/275/285).That's the exact combo I have, and it works perfectly
Not sure what you mean '5 wheel tire'. I went with 285s on the new wheels, retained the stock spare wheel and put a 275 on it, since it barely fit where the spare goes (285 absolutely will not fit with an 18" wheel, and anyone who says it does likely doesn't have it mounted flush to the 'ceiling' where the chain pulls it up).I believe I’m looking for this exact setup. I really like these wheels and want to stay close to stock on the tire size (265/275/285).
Question: did you buy a 5 wheel tire as a spare? Did it fit?
I meant 5th wheel - a spare. Your answer was perfect. I appreciate the guidance on the size of the spare tire.Not sure what you mean '5 wheel tire'. I went with 285s on the new wheels, retained the stock spare wheel and put a 275 on it, since it barely fit where the spare goes (285 absolutely will not fit with an 18" wheel, and anyone who says it does likely doesn't have it mounted flush to the 'ceiling' where the chain pulls it up).
Thanks for taking the time to compile and post this! Just picked up my J250 last week and have been confused about offset. Finally starting to sink in but notice that "40 degree offset" doesn't seem all too common. Do you all think that this will change soon due to the growing number of vehicles that seem to "need" this?Factory offsets are 70 or 60. The wheels for the nearly identical Lexus GX550 are 50. Icon has a video where they test different offsets for 18" wheels and concluded that of their wheels (vs. stock), 40 was the best offset for upsizing tires, if they pushed out beyond that (to their 25 offset wheel) it would hit the fender, stick out and spray mud/gravel down the side, etc.
Here's my list of wheels that are likely to work (from the spreadsheet linked in my signature), I don't have part numbers for all of them. There may be more Toyota wheels that work. If I end up with a Land Cruiser with 20" wheels, I'll get a set of the Tacoma wheels. The Sequoia wheel below is also a popular choice if you can get them cheap. If you know of more, let me know.
MFG Name PN Dia (in) Width (in) Offset (mm) Center bore (mm) Poke (mm) Delta (mm) Delta (in) Inset (mm) Delta (mm) Weight (lbs) MSRP Toyota Stock 1958 trim ? 18 7 70 95.1 32 ? Toyota Stock LC/FE trim 42611-60M70 (Gray) ? 18 7.5 60 95.1 35.3 0 0 155.3 0 27.3-31 ? Toyota Upgrade 20" wheel ? 20 7.5 60 95.1 37.2-40 ? Lexus GX550 Overtrail Wheel ? 18 7.5 50 95.1 45.3 10 0.39 145.3 -10 27-28 ? Toyota Sequoia TRD wheel PT960-34220-2F 18 8.5 47.5 95.1 61 25.7 1.01 155 -0.3 27-28.7 1120 Toyota Tacoma TRD wheel PTR56-35242-F1 18 8 45 95.1 56.6 21.3 0.84 146.6 -8.7 28-28.75 300 Icon RECON SLX ? 18 9 40 95.1 74.3 39 1.54 154.3 -1 36 340 Rays D108 38138855216BZZ 18 8.5 52 112 56 20.7 0.81 160 4.7 ? ? Rays 07X 10178803816BD 18 8 38 112 63.6 28.3 1.11 139.6 -15.7 ? ? Rays 07X 10178854416BD 18 8.5 44 112 64 28.7 1.13 152 -3.3 ? ? Rays 07X Limited 10218854416PH 18 8.5 44 112 64 28.7 1.13 152 -3.3 ? ? Method 318 MR318885601340 18 8.5 40 106.25 68 32.7 1.29 148 -7.3 29.7 299 Method 319 MR319885601340 18 8.5 40 106.25 68 32.7 1.29 148 -7.3 31.6 319 Bradley Forged Takumi ? 18 8.5 52 110.3 56 20.7 0.81 114.3 -41 ? ? Bradley Forged Takumi ? 18 8.5 40 110.3 68 32.7 1.29 114.3 -41 ? ?
Hopefully so. Especially now that the 4Runner is coming out, there should be a lot of demand. I got the Tacoma wheels with a 45 offset.Thanks for taking the time to compile and post this! Just picked up my J250 last week and have been confused about offset. Finally starting to sink in but notice that "40 degree offset" doesn't seem all too common. Do you all think that this will change soon due to the growing number of vehicles that seem to "need" this?
The Japanese aftermarket wheel mfgs have a lot of high offset fitments (40-50mm) for Land Cruisers, because their domestic regs do no allow 'poke' with tires exposed outside of the fenders. In other countries this isn't an issue, and many of the 6x139.7 aftermarket wheels have low or negative offsets. IMO you probably won't see a lot of choices for high offset aftermarket wheels for the 4Runner because most of those buyers prefer an "aggressive 4x4' look with a lot of concavity in an aftermarket wheel.Thanks for taking the time to compile and post this! Just picked up my J250 last week and have been confused about offset. Finally starting to sink in but notice that "40 degree offset" doesn't seem all too common. Do you all think that this will change soon due to the growing number of vehicles that seem to "need" this?
A knowledgeable alignment shop should be able to correct these types of handling issues with adjustments to toe and caster, no?I see a LOT of discussion about changing wheel offset to achieve a specific look or to be able to install desired tires. Every discussion is about wheel rub, but there is a more significant factor to consider and that’s “tramlining”. Changing wheel offset and tire width effect the propensity to “tramline” your vehicle, which could pose a significant safety risk if you go too far. Please do some research on this before you make your decision and understand the engineers didn’t randomly select wheel offset or tire size
No. Its not something an alignment shop can accommodate for.A knowledgeable alignment shop should be able to correct these types of handling issues with adjustments to toe and caster, no?
How do toe, caster, and camber adjustments to a suspension not affect handling issues such as tramlining?No. Its not something an alignment shop can accommodate for.
going too far can cause extreme case of tramlining where the car gets pulled off the road if you hit a soft shoulder. Scott Brady does a good job discussing and explaining this over at Overland JournalA knowledgeable alignment shop should be able to correct these types of handling issues with adjustments to toe and caster, no?
Sticking with a 40 to 70 offset wheel keeps things fairly stock. Toyota sells these with offsets of 70 to 50 (for the GX550). And Toyota has said this vehicle is designed for 33” tires without modifications.I see a LOT of discussion about changing wheel offset to achieve a specific look or to be able to install desired tires. Every discussion is about wheel rub, but there is a more significant factor to consider and that’s “tramlining”. Changing wheel offset and tire width effect the propensity to “tramline” your vehicle, which could pose a significant safety risk if you go too far. Please do some research on this before you make your decision and understand the engineers didn’t randomly select wheel offset or tire size
Yes, I think you’re right. My point is just that people need to realize there is more than just rubbing to consider. There are a lot of forces being exerted into the wheels and offset is carefully chosen by the engineersSticking with a 40 to 70 offset wheel keeps things fairly stock. Toyota sells these with offsets of 70 to 50 (for the GX550). And Toyota has said this vehicle is designed for 33” tires without modifications.
I appreciate the caution. I have the 58 and was disappointed to find out after purchase that the wheels were only 7in wide- rather than 7.5 of the LC/FE. Maybe it doesn't make a difference, but most tires I'm considering for stock wheels show width of 7-9 and while my wheels are technically in-spec, I'd feel a bit more comfortable if the wheels were more in the middle of the range.I see a LOT of discussion about changing wheel offset to achieve a specific look or to be able to install desired tires. Every discussion is about wheel rub, but there is a more significant factor to consider and that’s “tramlining”. Changing wheel offset and tire width effect the propensity to “tramline” your vehicle, which could pose a significant safety risk if you go too far. Please do some research on this before you make your decision and understand the engineers didn’t randomly select wheel offset or tire size
