Help me choose wheel - Method 703 vs 705
LCdad
Sep 9, 2024
20
5
NorCal
LC250
Any thoughts on which Method wheel to choose? Both are 17x8.5 +35 offset which is perfect for me.
Aesthetically I like the 703 symmetric spoke look but it also weighs 27.93 lbs whereas the 795 weighs 25.24lb, a whopping 2.5lb difference.
I assume the 703 may be slightly stronger but that wouldnโ€™t matter to myself.
I guess Iโ€™m wondering if the 2.5lb is big enough of a deal to choose the lighter wheel. Wheel weight would have a smaller effect than tire weight Iโ€™d think.
I prefer the 703s but you are the one that looks at your truck first thing when you come out to drive it. lol
I don't think the 10 lbs. of total weight difference will be noticed. You will notice the weight of a heavier, bigger tire however. Dissent Offroad said they were impressed with the power delivery of the new LC with massive 38" tires on their build. I will never turn my truck into a rock crawler but I was impressed to hear their take on the power of the new LC.
Just keep in mind that you've only got a few mm of clearance from the brake calipers with these 17" wheels according to Method. They fit, but it's a tight fit. Unfortunately they don't offer them in that same offset and 18". I keep reading the bead grid wheels are really nice. And there are more 17" tire options . . . so yeah, lots of good reasons to go with these. And just that one reason not to.
Personal opinion: I like the way the 705 looks, but I agree with beammeup that it bugs me with the 6 lug nuts! 703's then.
Ooh. I didnt even think of that. I agree the second design looks better, but itโ€™s heavier too
A 6 lug wheel with a 5 (10) spoke design offends my sensibilities. The 12 spoke design of the second picture is my preference. YMMV
I went with the 703s in Bronze for whatever it's worth. Same 17x8.5 +35. Should be here today and can hopefully post pictures.
I think the 705 design has a lot of the same lines as the LC and fits the truck perfectly. 703โ€™s look good on everything so you cannot go wrong with those. If I were going aftermarket, the 705โ€™s would be my clear choice.
Bronze is looking sharp! Thatโ€™s also not a big change in weight.
Yeah, I just went with standard load tires. I didn't want to increase the wheel weight a bunch as I don't do any rock crawling or towing either.
Picture as promised. Running 285/70r17 Falken Wildpeak AT4Ws. Stock 20's weighed in at 77lbs and these weigh 84lbs.
I ALMOST bought the 703s in bronze again for my WCP LC. I LOVED them on my army green Tacoma. I ended up buying the 17" 703s in Matte Black. I'm installing my Westcott lift this weekend and will probably do 315/70-17 Falken AT4w's and get those installed the following weekend. Hope it looks as good as this setup..
If your set on those two I like the 705 but Im a little biased im running 701's just because the 705 seemed a little busy to me.
Any pictures of the poke on this set up? I debating the same set up. Did you get the spare as well and did that fit without issues?
I really like the 701's. I had a set on my F350 SRW and they were great. I wish they had a higher offset as I would use that wheel again on my Land Cruiser. I love how simple the design is.
