Has anyone researched if a GX550 fuel tank is a direct fit in a Land Cruiser? ...and if so- what would be required to do the swap?
Looking at photos of the under carriages, the only thing I'm unsure on is if the Hybrid motor/mount is going to interfere. Don't know how the Lexus dealer would feel about me rolling under one with a tape measure and taking pictures...... might just have to find out.....LOLDepends what the definition of expensive is.
Curious if the pump/sender/mounting brakets, etc. can be reused and its simply the tank or if its an entire assembly. The old retired parts guy in me is curious.
Not a problem if you have mad gas tank skills!I’ve read in the manual that the LC tank is pressurized with special valves for the hybrid system. Not sure a direct swap is possible.
I believe the vapor purge capture system may put a slight vacuum in the tank. Also why the gas tank cap has to have a proper seal ("O" ring) in order not to throw a CEL light and trouble code.I noticed that presurized commment in another thread. That seems very odd (not saying it isnt true). By what means would the tank become presurized and why? I could see where the tank would be slighly under vacuum, due to the draw of the fuel pump- and for emission compliance reasons. I also assume this is a direct-injected engine with no fuel return line.
…..”ensure that all the doors and windows are closed”.From the manual. I did a google search as to why and it said it has to do with the “instant on/off” feature of the gas engine in the hybrid system. View attachment 4639
