Has anyone researched if a GX550 fuel tank is a direct fit in a Land Cruiser? ...and if so- what would be required to do the swap?
Looking at photos of the under carriages, the only thing I'm unsure on is if the Hybrid motor/mount is going to interfere. Don't know how the Lexus dealer would feel about me rolling under one with a tape measure and taking pictures...... might just have to find out.....LOLDepends what the definition of expensive is.
Curious if the pump/sender/mounting brakets, etc. can be reused and its simply the tank or if its an entire assembly. The old retired parts guy in me is curious.
Not a problem if you have mad gas tank skills!I’ve read in the manual that the LC tank is pressurized with special valves for the hybrid system. Not sure a direct swap is possible.
I believe the vapor purge capture system may put a slight vacuum in the tank. Also why the gas tank cap has to have a proper seal ("O" ring) in order not to throw a CEL light and trouble code.I noticed that presurized commment in another thread. That seems very odd (not saying it isnt true). By what means would the tank become presurized and why? I could see where the tank would be slighly under vacuum, due to the draw of the fuel pump- and for emission compliance reasons. I also assume this is a direct-injected engine with no fuel return line.
…..”ensure that all the doors and windows are closed”.From the manual. I did a google search as to why and it said it has to do with the “instant on/off” feature of the gas engine in the hybrid system. View attachment 4639
Agreed on all points, very interested in that 30 L aux.I was able to do a little more research on the international models. What is interesting is the Aussie version Prado has a 80L primary (21.1 gallon) and a 30L (7.9 gallon) secondary tank. The fact that the international version and the GX550 share a near identically sized tank is promising that there should be a factory solution that will fit in the same footprint. Of course- still waiting to find parts schematics and part numbers for the US LC and the GX550 to see how many parts are in fact interchangable. The variable is- what will Long Range America bring to market and will it take up space in the spare tire well.
Here we go! Is this going to be done by the Ed Martin Toyota crew?GX tank and parts that might be needed have been ordered (not sure if the GX fuel lines will be needed). None are in stock in the US, so awaiting the arrival from overseas. Once they arrive, we'll see............
Yes, I'm pretty sure I could DIY, but I don't have a lift and if any unforeseen problems arise, I don't have access to the Toyota/Lexus parts line etc........Here we go! Is this going to be done by the Ed Martin Toyota crew?
Very interesting! Do you have a take yet on those claiming that Toyota's non-hybrid gasoline tanks are fundamentally different than hybrid gasoline tanks and therefore completely non reverse compatible? They point to the warning about the tank being "pressurized" in the manual. However I suspect this is just a function of the environmental vapor recovery system common in all modern fuel tanks. Others claiming the continuous on/off of the ICE engine requires different fuel supply pumps. However, you seem to have identified that the the fuel pump is actually the same.Yes, I'm pretty sure I could DIY, but I don't have a lift and if any unforeseen problems arise, I don't have access to the Toyota/Lexus parts line etc........
Hopefully the tank and sealing gasket are the only parts needed. He ordered the fuel lines in preparation, but unless the fuel pump/sending unit's actual location, relative to the LC's frame, is way off, they will most likely be returned.
My logic is: the LC's pump is the same part number as the GX so it can be reused. The pump supply line and return line connections would be the same on the LC and the GX. The I4 fuel rail connection and the V6 fuel rail connections might be different. The fuel rail return and purge line connections might be the same.
We'll see when the parts arrive.
