Climate settings to avoid condensation
planisher
đź“› Founding Member
Jun 23, 2024
40
42
Ontario, Canada
Now that the weather is colder I find the rear of the vehicle gets foggy quickly. Running the front defrost removes it but if I turn it off the condensation comes back. Any tips on climate settings to avoid this?
Run the AC. It’s the only device in your car that can remove moisture from the air.
Yes - that’s what I thought as well. I have it on Auto with the A/C on. But that doesn’t seem to pull the moisture out of the rear of the car.
It might help to manually keep the fan going at a mid speed if you find that it is turning off
There is a rear climate control system in your LC. Turn it on, and Make sure the vents are open back there.
