Was there more room once you removed plates?Was able to do the first oil change without ramps. For context, I'm 5'6", and it was a little tight but doable. Probably 3 inches of clearance from face to skid.
You'll need to remove the front skid to get to the oil filter. Once it's removed you'll have enough room to reach for and remove the filter.Was there more room once you removed plates?
I have some metal ramps that I haven't used in years. But all my recent vehicles I could change oil without ramps. Everyone said it's a pain to put back skids so I may have to pull out my ramps.If you have the storage space, I would just get a pair of ramps. Will make your life a lot easier, especially if you plan on doing oil changes in the future.
I did it no problem but I’m not overweight like 160 lbs. skid plate is a little heavy and cumbersome but no big deal and that was the first time. The main thing is the oil filter is right there so it’s no issue at all. Did not use a creeper. Definitely easier than my new F150 which I also do without ramps.Im thinking of doing 1st oil change without using ramps, but it looks a little tight because of skid plates. Does removing skid plates get you a lot more room to move around under there?
I have a LC/LC so the skid plates should be easier to handle under there. I think the FE skid is a longer one piece and heavier.I did it no problem but I’m not overweight like 160 lbs. skid plate is a little heavy and cumbersome but no big deal and that was the first time. The main thing is the oil filter is right there so it’s no issue at all. Did not use a creeper. Definitely easier than my new F150 which I also do without ramps.
It’s fast and safe whole job start to finish with clean-up in under 1 hour.
BTW I don’t trust the plastic ramps they break for sure.
$59 at Auto Zone…Im thinking of doing 1st oil change without using ramps, but it looks a little tight because of skid plates. Does removing skid plates get you a lot more room to move around under there?
I attempted it without ramps a few days ago and it too close for comfort for me. Definitely easier with ramps
That's what I'm hoping for.I don’t use ramps. Once you get the skid plates off there is plenty of room.
