I have the $70 metal ones for Horrible freight in Florida, and the $60 plastic ones from Auto Zone in NC. I think the metal ones are slightly higher. But the plastic ones are definitely lighter and easier to carry around for storage. 6 one, half dozen the other.For FE - can you take off the front skid without removing the rear skid? I have a vacuum pump to change oil so only need to remove the skid to change the filter.
What are the preferred ramps everyone is using?
If you remove the skid for the filter, it also allows access to the oil drain plug.For FE - can you take off the front skid without removing the rear skid? I have a vacuum pump to change oil so only need to remove the skid to change the filter.
I've been using my plastic Wally World ramps for the last 20 years. I'm still alive so appears to be doing its job.What are the preferred ramps everyone is using?
2 or 4 ramps? Thanks!I attempted it without ramps a few days ago and it too close for comfort for me. Definitely easier with ramps
Just 2!2 or 4 ramps? Thanks!
2 under the front wheels.2 or 4 ramps? Thanks!
Fumoto F-133N drain valve - M12-1.25 TPI.What are the threads on the LC? I wish to purchase a drain valve, most likely a ValvoMax. However, recommendations?
Did you torque it to specs, i.e. 25 lb-ft? Reading reviews on it and the competition, and an uncomfortable number of folks have encountered issues, twisted off, etc. It appears to come with a fiber washer, and they caution to tighten 1/8 turn from contact, no more. Possibly some folks overdo?Fumoto F-133N drain valve - M12-1.25 TPI.
From another post - ValvoMax Oil Change System in M12-1.25 TPI.
I use the Fumoto in all my vehicles. I leave aprox 8" - 10" of hose semi prem attached to the valve and just lay it on the skid plate and place the vinyl cap that comes on the valve, on the end of the hose to keep the dirt out. I have a ValvoMax type in my lawn mower and don't like it, but it's the only one that'll fit.......LOL
You will never get ALL of the oil, to fully drain. Because of the location of the plug, there may be an ounce or two of oil in the bottom of the pan.Do the ramps allow the oil to fully drain? I would think so if the drain plug is in the back of the pan. I'm getting ready to do my first one tomorrow. Been doing them on our 2019 and no rams. But ramps would make life much easier.
Plastic Ramps at auto zone are $50, and lighter and easier to move about and store that the steel ramps from Horrible Freight, which are ~$75-$80 IIRC. The Horrible Freight ramps may be an inch taller..You can definitely do it without ramps, but it’s a bit tight. I just paid $50 at my local DIY garage and put it on lifts so I could stand under it.
You will need a crow’s foot ‘socket’ to torque the Fumoto. I don’t remember what size it is. Put it on your wrench at a 90° angle to get an accurate reading of torque.Did you torque it to specs, i.e. 25 lb-ft? Reading reviews on it and the competition, and an uncomfortable number of folks have encountered issues, twisted off, etc. It appears to come with a fiber washer, and they caution to tighten 1/8 turn from contact, no more. Possibly some folks overdo?
I regret buying steel ramps, the noise they make when sliding across polished concrete is shocking. Plus they weigh a ton and dont stack or stand on end for storage.I've been using my plastic Wally World ramps for the last 20 years. I'm still alive so appears to be doing its job.
