Winter Tire Wheels Offset Question
ztz
πŸ“› Founding Member
Apr 14, 2024
39
12
BC
Mercedes
I am thinking to purchase a set of wheels for the winter tire, which is 265 70/R18 but have no idea what will be the good offset for the rims? I have the 20 inch OEM wheels which have offset 60 and it is impossible to find the same offset wheels. If I bought a set of 18 inches wheels of offset 30, will them fit?
I would do +40-45, because it would allow you to fit bigger tires later if wanted.
I just use it for winter tires and probably won't put bigger tires. Will 30 work?
30 would stick out a bit further than necessary for a 'stock' size, but some people like that.
Will 35 stick out a bit further? Or 40 will be ideal?
It really depends on how wide a tire you're going to install; 35 would stick out a bit further, but with a narrow (stock) tire it would likely not be very noticeable. With a wide tire it would be noticeable.
Mine are +25 offset and I think they are just right. Maybe .25" poke.
The winter tire will just be 265 70/R18.
17" BLACK RHINO RIVAL 17X8.5 6X5.5 106 +25 M-GNMTL MBLK
35x11.50r17 TOYO OC AT llI
