Wheel upgrades
OK, so consensus is that the Method 703s fit in the below sizing and +35 offset:
Next question: which KO3 tire best fits that wheel on stock suspension settings; I.e. no lift kit, etc.?
With about 5mm clearance from the brake calipers according to Method.
I wish they made 18" 70x wheels with the 35 offset. The best they offer is 18 offset.
I started a list of stock-ish offset 18" wheel options on my tire spreadsheet if anyone has suggestions to add.
Search around on similar threads there are plenty of people running KO3's here and have offered tons of advice. Personally am going with 285/70/R17C KO3s for a smoother ride instead of an E rated tire.
And you are putting those on stock wheels, or getting something different?
I'm getting the Method 703's in +35 offset until something better comes out. Praying that TE37XT's are made with a more favorable offset in the future.
Interested in fitment (caliper clearance, ect) please keep us posted!
If anyone is considering the Bronze Method 703s, I have a complete set for sale in the marketplace section.
Perhaps I missed this… but I just found out that the factory 22-24 tundra wheels bolt on directly. I thought I saw trd pro wheels on a couple but I did not realize they were the exact wheel.
Yup - pretty sure its Tundra / Sequoia / Tacoma / 4Runner (All new generations) share the same bolt pattern, hub bore, lug, ect.
Do we know the part number for those 18 inch wheels?
Or even the part number for the stock 18 inch wheels coming with the LC?
I have a few but not all of them on my spreadsheet (linked below). If anyone can find the rest that would be great.
MFGNamePNDia (in)Width (in)Offset (mm)
ToyotaStock 1958 trim?18770
ToyotaStock LC/FE trim42611-60M70 (Gray) ?187.560
ToyotaUpgrade 20" wheel?207.560
LexusGX550 Wheel?187.550
ToyotaSequoia TRD wheelPT960-34220-2F188.547.5
ToyotaTacoma TRD wheelPTR56-35242-F118845
Thanks!
Don’t all LC come with black lug nuts?
Update on 18” TRD wheels
Very nice! I’ve got a set of these that will hopefully be here Sat or Mon. They’re apparently becoming a bit difficult to find as well as the matching TRD center caps. I’ll be putting 285/70 Wildpeaks on them. Anyone needing a set of stock LC 18” wheels and tires in Colorado Springs?
Came across these Fifteen 52 Bundt SV wheels that are made for Sprinters. I think these would look awesome on the LC! I'd love the Magnesium Gray versions with 34" BFG KO3's. And they're already made in +40mm offset. I emailed them to ask if they'd PLEASE make these in the Toyota bolt pattern. Bundt SV _ Magnesium Grey
