WeatherTech FloorLiners now available for 250
They arrived today and fit great, I am super pleased.
I have not lived in a deep winter region to test constant salt exposure but I have put 4 or 5 sets thorugh the ringer with other outdoor wear and tear and have not had the severe curling folks mentioned.
*One thing to note is that for the 250 these are the allegedly new and improved FloorLiner HP model "high performance". They cite a good bit of increased durability but time will tell...
"FloorLiner HP
WeatherTech’s talented designers and engineers have taken our already advanced FloorLiner into the future! Laser measured and custom fit, FloorLiner HP is the next generation of high performance FloorLiner. Designed to protect your carpeted floors as well as the front, back and sides of your vehicle’s footwell.
FloorLiner HP is made using advanced rubber-like, Thermoplastic Elastomer (TPE) compound making it both soft and durable. Engineered and created to stand up to the most extreme weather conditions, it won’t crack, curl or break down. This material is also 100% recyclable and is both latex and PVC-free!
A specially designed retention system and non-slip nibs keep the FloorLiner HP locked in place, so there’s no sliding. Its beveled edge prevents walls from curving in, for the ultimate in stability. When applicable, a watertight seal around the retention clasps helps prevent messes from leaking onto your vehicle’s interior carpet. Optimal side trim lines cut away to display the seal plate on your vehicle."
View attachment 19930View attachment 19931View attachment 19932View attachment 19933View attachment 19934View attachment 19935
Are these going to cover up half of the LC/FE lit door sills I just bought? :(
this is what i ordered and its on SALE
Isn't there a difference in the material between WT and Husky? I always found it hard to keep the WTs black looking good. Anyone know if Huskys are better from that regard?
I just ordered the huskey liners. It looks exactly same as the weathertech and they are both made in the USA.
Sorry, but I bought Husky once to save money. They are not the same quality. They warped easily. Been buying Weathertech ever since.
It seems like many people might be overlooking that these are WeatherTech’s new “FloorLiner HP” model. They feature a “lattice” reinforcing structure on the underside, which I’ll try to snap a photo of and share later. I can’t guarantee they won’t curl over time, but they feel noticeably more robust compared to their standard FloorLiners I’ve used in my previous vehicles.
So it's even better. Even the old versions were great.
Received the Weathertechs today, and they have much, much better coverage for snowy/wet environments. The stock mats left much to be desired around the gas pedal, where snow would have gotten on the carpet constantly. I also like the one-piece rear mat that goes over the center plastic hump.
