Towing a Mammoth Overland Tall Boy with LC Fe
ricochet
36
116
Washington State
2024 Land Cruiser FE, 2024 Ranger Raptor, 2021 Subaru Crosstrek Sport
Had some fun towing the Mammoth Overland Tall Boy. The perfect trailer if you want those post-apocalyptic vibes and don't mind spending $80k. Oh, also I had a good experience towing with the LC, though it does have a few eccentricities.
What are the odds Toyota does something about the towing software? I don’t have a lot of experience with this manufacturer and how they refine (if they refine) the tech.
Considering how slow Toyota is with updating their 'tech' features, the LC will probably be like a mammoth frozen in a glacier before Toyota does anything about it.
It certainly could be better software-wise (esp. re: turning off sensor warnings, remembering settings), but for those who only pull one trailer it's not that terrible. Certainly way better than the '16 4Runner I came from.
So do you have to go through all the setting again when stopping for fuel. I think I know the answer but… dang
No, just doing initial setup for the specific trailer. It will hold the settings but has no way to store the settings if you have multiple trailers.
I'm still a bit fuzzy on what hitting the "Tow/Haul" button actually does. I think I looked it up in the manual and it didn't have much detail.
Locks up the torque converter to prevent overheating. Interestingly, it also disables all forms of cruise control.
In the video he says the the assisted cruise control is disabled. Regular cruise is still available. Is that not the case?
You can use regular Cruise Control if you do not use Tow Mode. If you turn Tow Mode on, then you cannot use any CC. Because our highway run was relatively flat, I wasn't using Tow Mode until we went into the mountains. I could/should have been clearer about this, but we were also figuring it out as we went.
