Tapping power from USB-C harness?
Indecent Dad
11
11
Houston
Grand Cherokee, Telluride, Land Cruiser
Hoping someone with experience in this sort of thing can chime in….
I need a usb-c cable on the back side of this switch panel to charge a device out of sight (charge only, no data).
I am trying to avoid a fuse tap since the only fuse panel I can find is in the engine bay (side question…is there a fuse panel under steering column??)
I assume the USB-C harness will already be converted to 5V DC for the pre-existing charge ports on the right??
Is tapping pre-existing wires here a bad idea?
So two solutions........
There is an interior fuse panel under the glove box (remove the trim panel).
Purchase a splitter from Amazon and new OEM port, remove the existing port, split it behind the trim panel, install new port into original hole.
Perfect! Interior fuse panel it is - looks close enough to where it won’t be a pain running a cable. Thank you!
