Stock-like Auxliliary Switch Panel
Awesome work!
I integrated a flashlight charger into my panel which I’m liking at the moment, but after cutting a hole in it I kept thinking “no going back now!”
Will definitely purchase once I get something switch-worthy
Awesome work!
Thanks for the support! I can send some switch blanks as well if you want to add switch-worthy add-ons one by one.
Just received mine, excellent fit in finish A+
I’m gonna need a detailed write up on the install from EOD guy before I tackle this. Also need to get some more lights and air compressor wired up first so I don’t have to keep pulling everything apart
There's no need for a detailed write up........... as easy as it gets!
There are 3 fasteners holding the trim panel in place. I start on the R/H side with a trim tool and pry up that edge, then insert the "L" side of the trim tool, work around to the other two and the panel pops straight out. Reuse the 3 orange fasteners........ done.
I was actually referring to running the trigger wires from the engine bay to that location, but thanks for the pics!
@SkookumOffroad can you make an alternate version with a storage cubby where those 3 buttons are? I have filled the other 3 blank locations I have and that's all I want in the short term. Just looking for another spot to put junk.
