๐Ÿ› ๏ธ Member Build Siblue Heritage blue
Member Build
Siblue
Mar 31, 2024
79
77
91710
24 Land Cruiser, 24 GR Corolla, 22 Tundra
Picking this up tomorrow.
Wheels and KO3 will be mounted after delivery
BFG KO3 275/70/18E white letters out
Tacoma accessory wheel
Tundra 1794 Special Edition Center caps.
RAV4 volume knob mod from TW. Also works on our GR.
Repurposed my DIY VLEDs footwell lights from my GX.
Front and rear footwells complete.
1st try was tapping ambient LED circuit. That circuit works with dome trigger and parking lamp
2nd attempt was tapping door sill circuit, instant trigger and works front two doors only.
3rd and final attempt, I was able to tap dome circuit. Works off the dome switch overhead.
45mm
Whatโ€™s the part number on those wheels? I like them, but I seem to not be good at searching for exact wheels. Also, do you happen to know weight? Thanks
A bit difficult to see in this screen shot
PTR56-35242-F1
27.71 lbs
MESO customs Minimalist Key Fob V3 Tundra/Sequoia/Tacoma
Comes with interchangeable tailgate button for trucks and blank for GRC
Used the hatch button for LC.
You quoted other member but Iโ€™ll chime in. Wheels do not come with center caps.
Another TW mod. Static Chalk bag used as a large drink container holder.
Maxpedition Triple Mag Holder for miscellaneous items.
Toyota illuminated door sills.
All in one photo.
A must on all our Toyotas. Disable all seatbelt dings using Carista.
Also enabled windows.
Do you still have the part number for the 1794 Tundra wheel center caps?
PT998-35221-3S
