Pro trip:You must be an extraterrestrial alien with ET fingers, because that's way deep in there. Thought about removing the grille, but that seems to be a bitch too.
Is your badge backwards? I thought the yellow was at the end or does it matter?After removing the shroud like @EOD Guy suggested, I used a small ratchet along with an extension and deep well socket to install mine. Was pretty fiddly to install with the grille shutters in the way, but I'm happy with the result!
Can I ask where you get drawings and instructions like this? Do mortals have access or just special people?I've never had it completely off and it looks quite involved, not hard but a lot of pieces.
My suggestion is to use colored sticker dots or pieces of painters tape to mark the locations/holes of the bolts/fasteners you remove. Having removed many of the panels on my LC at some point, I can tell you that even with a lot of experience as a mechanic and thinking "I'll remember where everything goes" The LC has so many panels that interlock/overlap and so many different types of bolts/screws/fasteners it's very hard to keep track of all of them.
When removing something I've never removed before, I normally use my cell phone and take a picture of each step etc........ even that method had me scratching my head. I purchased some colored sticker dots from Amazon (4 colors), I place a dot on the fastener and same colored dot on the hole (same color for each type fastener) it, along with pictures, allows a simple reassembly process.
Anyone can subscribe to Toyota's TIS website. I think they have a 3 day, 30 day and annual subscriptionsCan I ask where you get drawings and instructions like this? Do mortals have access or just special people?
Thx
I've seen it yellow/orange/red, but I'm certainly no expert! Not planning to change it, because it was a PITA.Is your badge backwards? I thought the yellow was at the end or does it matter?
I need to know before I install mine
I could not figure out how to get in there as well from the radiator side because of the louvers. However, I went to the hardware store and purchased wing nuts. I used orange Loctite to set the screws into the badge, followed up with the bolts that came with it. Then, the wing nuts were a little wonky, as they would stop. So, I ran them all the way down to straighten out the thread. Then, if you have them on the far end, you can slip one side in the front and turn out the other side and put the plastic holder in place with and the wing nut. Then I reached in the front with my fingers and tightened them it up, making sure to put some more Loctite where they would be sung. VIOLA!! My first mod!I bought the TRD badge, tried for 30 minutes to get it installed, and finally gave up. No badge for me unless I get really bored and creative this winter.
I’m laughing because I’ve removed the 8/3 and nothing. Trying to get that damn grill emblem on it.Does anyone have the steps to remove the front grill? I’ve removed the top cover (8 push clips) and the three 10mm bolts, but she won’t budge
That's because there are a lot more fasteners than 8/3...... see post #3 above for the removal PDF that will give you the locations. Also if you search uTube for 2024 land cruiser headlight swap (or something like that) by Ed Martin Toyota they show what's involved.I’m laughing because I’ve removed the 8/3 and nothing. Trying to get that damn grill emblem on it.
